Old 08-17-2011, 02:56 PM   #1
need help diagnosing codes, p0300 etc
hello, i could use some help. i just pulled the following codes p0300, p301, 302, 304, 305. i know this means random misfire, whats my next step?
juicepro is offline   Reply With Quote
Old 08-18-2011, 07:22 PM   #2
copsahl's Avatar
Symptons?
What were the symptoms leading up to the CEL?
copsahl is offline   Reply With Quote
Old 08-19-2011, 04:25 PM   #3
just bought the car last week so i don't know the symptoms leading up to it. i only realized when driving above 5,200rpm(cel light flashes) so far i've checked for a vacuum leak, cleaned MAF and switched the coils around but still the same codes. i'm going to try changing out the sparks plugs and go from there, any suggestions please?
Old 08-20-2011, 04:29 AM   #4
Johnny Danger's Avatar
You may find this link valuable .
http://boxster.wikia.com/wiki/CEL_Error_Codes
Old 08-20-2011, 02:37 PM   #5
copsahl's Avatar
If the faults are only at higher RPMs, I'd guess the misfires have to do with valves/valve timing. But, others on the forum may have a better idea.
Old 08-20-2011, 05:48 PM   #6
it doesn't look like this car has been serviced for a few years, i've ordered an air filter and plugs we'll see if that changes anything. thanks
Old 08-21-2011, 06:37 AM   #7
Porsche "Purist"
Paul's Avatar
Are you "feeling" the misfires?
1987 924S. 2002 996TT. PST-2
Old 08-21-2011, 03:06 PM   #8
"Are you "feeling" the misfires?"
No, the car seems to feel and drive fine, but i only just got it last week so it's hard for me to have a baseline "feel" for this car.
Old 08-21-2011, 03:41 PM   #9
Porsche "Purist"
Paul's Avatar
I agree, let's see what new plugs do.
Old 08-23-2011, 05:00 PM   #10
just changed the plugs and now it's running worse than before, maybe the MAF?
Old 08-24-2011, 02:36 AM   #11
You just bought the car
What was its history before you bought it? Do you have a great local Porsche mechanic available (Someone with a PWIS or PSTII and the knowledge to use it)?
A flashing CRL light says "very serious...don't drive...you risk blowing the engine". Get professional help.
Old 08-24-2011, 05:33 AM   #12
sorry mike, i don't know much about the vehicle apart from it having 3 owners, the last owner had it for 3 years (30k) and never serviced it.
i was going to try and disconnect the MAF and see if it runs any better. if that doesn't work getting it towed to Fresno Porsche(60 miles away) is my last option. thanks for all the help guys! i'll keep you posted.
Old 08-24-2011, 03:54 PM   #13
just an update. car is running better today, back to throwing flashing CEL only above 5,200rpm. still planning to get it looked over by dealership but hoping to drive it there instead of tow. i'll cruse around town for a few days to see how it feels first.
i can rule out air filter, sparks plugs, MAF and coils.
Old 08-30-2011, 07:34 PM   #14
Hi guys, i got some bad news today. The dealership called and said i have vibration coming from the engine that is likely a failing IMS and that i would need an engine rebuild. The car is a 02 boxster 69k that i bought recently for $12k. I'm stuck and don't know what to do, any suggestions?
Old 08-30-2011, 07:50 PM   #15
Topless's Avatar
Your options are to fix it or sell it as a dead roller for maybe $5K. Get a second opinion from a qualified Porsche indy who knows their stuff. If the IMS has not failed yet the motor can probably be saved. TRG is in Petaluma Ca, 911 Design in Montclair, Tony Callas in Torrance. All are excellent. Where exactly do you live?
Old 08-31-2011, 05:25 AM   #16
i'm going to start calling some independent porsche shops today, i live in the central valley but will probably have to get it towed to the bay area.
the car still drives, does this mean my motor is still ok?
Old 08-31-2011, 06:52 AM   #17
If the IMSB has not failed, then its possible to save the motor with an IMSB replacement, $1500-2500 is the going rate. The dealer usually will not replace IMSB, they want to sell you an entire motor.
DO NOT DRIVE OR START THE CAR and take it to an independant who can verify the IMSB diagnosis. One thing you can do is look at the oil filter for ferrous metal and drop the sump plate to look for pieces of the IMSB to verify the diagnosuis.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
