Old 08-06-2011, 02:12 PM   #1
jsceash's Avatar
Swap transmission
I've been noticing a little slip in my clutch when autocrossing, and everything is hot. I'm replacing the clutch. Has anyone ever thought about changing the boxster 2.7 5 speed out with a 3.2 s 6 speed. I have all the normal modifications and some extra. So the horsepower is not an issue. Any information?
Old 08-06-2011, 06:59 PM   #2
Crazy Austrian
harryrcb's Avatar
Aside from the expense I don't see an issue. I have one for sale if you are interested.
Crazy Austrian 007
http://www.ws-ab.com
harryrcb is offline   Reply With Quote
Old 08-06-2011, 07:01 PM   #3
Will it bolt up the same?
"You finally got that Nazi-go-cart you always wanted." -Peer
http://i40.tinypic.com/ei6sns.jpg
pompous is offline   Reply With Quote
Old 08-06-2011, 07:28 PM   #4
I had asked about 6 spd swapout some time ago.
don't know how to link the threads but if you search using "6 spd mated to 2.7L?", there's some info there
sb01box is offline   Reply With Quote
Old 08-06-2011, 09:22 PM   #5
JAAY's Avatar
I have a cayman tranny. You just need a six speed clutch disc and flywheel and pressure plate.
Old 08-07-2011, 12:05 AM   #6
Changing to a 6 speed will not be god for your autocrossing as it has higher gearing than the 2,7. If you go the other way and change to a 2,5 I guess that acceleration will be really improved for autocross.
Also drive shafts has to be exchanged if you go for the 6 speed as they are different in length
spongebob is offline   Reply With Quote
Old 08-07-2011, 04:59 AM   #7
Porscheectomy
Why? The 6 speed has a chasm between 2nd and 3rd, and 5th is useless. I gues it's a little stronger but are you having problems with gear teeth breaking?
Old 08-07-2011, 05:17 AM   #8
if u have transmission issues you could give these guys a call GBOX
I have never done business with them but i have talked to them before and are very helpful
Old 08-07-2011, 08:41 AM   #9
jsceash's Avatar
no issues
I'm not having any problems with my transmission. I'm replacing my Clutch. pressure plate, and flywheel. I saw a coulpe good prices on 6 Speed. The 03 manuals say every gear is a higher ratio with less span between every gear, .62 span between 1-2 on the 5spd . 38 on the 6spd. , .69 span 2-3 on the 5Spd, .68 on the 6spd. The only down side I saw was top ratio .84 on the 5spd and .89 on the 6spd which means worse fuel economy. The number should produce a quick acceleration curve, minus shifting time.
Old 08-07-2011, 09:19 AM   #10
Porscheectomy
Look at the final drive ratio too.
Old 08-07-2011, 09:26 AM   #11
LAP1DOUG's Avatar
I have a Boxster S with the 6 speed, and I was thinking about going the other way and converting to the 5 speed for autocross - want to swap?
Actually, the final drive ratio on the 6 speed is ususally a handicap for most autoccross courses. It is numerically quite low, and so you give up some acceleration.
The 6 speed in 2 nd gear does not red line until about 74 MPH which is a rare top speed for autocross. For best acceleration, you would want red line to occur at a more normal 65 MPH or so maximum top speed for autocross.
Kippis
986S
991S
Van Diemen RF97
Old 08-07-2011, 02:37 PM   #12
jsceash's Avatar
Is the actual ratio in any gear is the (transmission gear ratio X the final drive) or is it transmission divided by the rear ratio.
Old 08-08-2011, 07:03 AM   #13
You multiply, so a 2.95 first and a 4.10 rear give a total gear reduction of 12.095.
