Old 08-01-2011, 06:52 AM   #1
Windshiel Washer Tank
Hi Class. Yesterday I was putting in an amp & speakers. Get the job done and go to put on the trim around the winshield washer tank cap. I must have moved it, because then it started leaking. How do you get to it? I need to take a look and see what's cracked/broken/dissconnected. I assume you need to take off the tire and wheel well cover? Looks like a PITA.
Old 08-01-2011, 07:40 AM   #2
Yep
Tank is accesible from the bottom with wheel well liner removed. Bet the hose is loose...BTDT
John
jrj3rd is offline   Reply With Quote
Old 08-01-2011, 08:05 AM   #3
Hi. Thanks for the reply. I hope that's what it is. I'll share the repair info once I get into it.
