Old 06-22-2011, 02:19 PM   #1
Johnny Danger's Avatar
Side Intake Mesh ?
I'm looking for advice regarding what size mesh in should use on my side air intakes ? My goal is to remove the factory "louvers", and create a simpler more stylish look . Any thoughts ?
Old 06-22-2011, 02:21 PM   #2
And another photo .
Old 06-22-2011, 02:40 PM   #3
ddb
www.klisstle.com
ddb's Avatar
JD,
No help on the mesh, sorry.
What's the deal with those openings? They look as if there's more going on than just the OE louvers being replaced.
ddb
Old 06-22-2011, 02:56 PM   #4
Originally Posted by ddb
JD,
ddb
Good eye. Basically, the the entire oem insert has been removed and replaced with just mesh . Here's another perspective on what I'm considering doing .
Old 06-22-2011, 03:02 PM   #5
As you might expect, this is how things currently look .
Old 06-22-2011, 03:16 PM   #6
ddb
www.klisstle.com
ddb's Avatar
I like the mesh with the painted insert left installed. The depth is appealing to me.
Have you thought about black mesh versus yellow mesh?
Old 06-22-2011, 03:30 PM   #7
Definitely black mesh, not yellow . Here's another option. It's a turbo style intake designed to fit the 986 .
Old 06-22-2011, 04:55 PM   #8
ddb
www.klisstle.com
ddb's Avatar
I believe I like the split opening on the Turbo because the opening is taller. On your 986 I like the OE opening with the black mesh to pick up on those black wheels.
BTW, are your wheels flat (or semi-flat black) or do they have more gloss to them than appears in the pic?
I've often thought about having the spokes on my wheels painted black. Thus far I've been too lazy to do it.
Old 06-22-2011, 05:45 PM   #9
They're gloss black .
Old 06-23-2011, 06:12 AM   #10
Allen K. Littlefield's Avatar
Dear Mr. Dan Gerous, I like the smooth transition into the nostrils (as opposed to the 'gills' on the newer Boxsters). It would seem that you would need a whole new rear quarter panel with this modification or is there another way to 'french' in the opening?
I am not personally fond of black painted wheels as it makes them hard to see and detail is lost, at least to these tired old eyes. Otherwise car looks great. Party ON!
AKL
Old 06-23-2011, 06:17 AM   #11
AKL
Same quarter panels, they plug right in .
Old 06-23-2011, 06:24 AM   #12
Opposed to Subie Burble
Overdrive's Avatar
The turbo look is nice, where can one get a set of those?
-O/D
IMSR + RMS
Robbins glass window top
Old 06-23-2011, 06:36 AM   #13
I was referring to the white and yellow examples in the first couple of posts as I see no seam. The split turbo examples look like they would plug right in.
aKL
Old 06-23-2011, 09:30 PM   #14
Jager's Avatar
Here's another look...
[url]http://www.lltek.com/porschtek/Bxstr_986_kevlar_CF.htm[url]
Old 06-24-2011, 07:56 AM   #15
aKL
The yellow and white vehicles have had the oem inserts completely removed, and replaced with just mesh .
Old 06-24-2011, 09:14 AM   #16
but on the stock piece is there that much lip? it seems that rear quarter in those pics is from a wide-body kit and designed with a deeper lip. I could be wrong though.
Old 06-24-2011, 09:35 AM   #17
The Radium King's Avatar
here's an image of a stock fender without the vent:
http://i84.photobucket.com/albums/k2/grizzly_011/DSC00831.jpg
so, there's obviously some bodywork going on with those white/yellow cars. more likely, those look like aftermarket widebody fenders.
Old 06-24-2011, 09:54 AM   #18
Overdrive's Avatar
Well, those are Gemballas, so the wide body speculation would be correct. Personally, I don't like that look all that much, but the ones that still contain an insert with a different style or mesh look good to me. That turbo-style one is really nice, it actually blends with the car's basic look.
-O/D
IMSR + RMS
Old 06-24-2011, 09:59 AM   #19
Interesting point. So far as I know, the Gemballa kit retains all of the oem parts (except the hood), to include the fenders . I was under the impression, that if you remove the insert portion of the side intake, the remaining channel extends further inward than the photo RK has posted . In any case, it seems that the turbo style intakes win out .
Old 06-24-2011, 10:13 AM   #20
There's one more style that I forgot to mention; the Techart intakes . Yes, no, maybe ?
