Old 06-25-2011, 01:26 PM   #4
Originally Posted by shlim8
I have a similar situation - I'd posted a thread on this too and to be safe, I'm going to replace the driver side (passenger side for me as RHD - but same side as yours) series resistor. There was some debate on whether both fans were supposed to run at low speed when the a/c is off, but no definitive answer.
I've also asked a couple of independent mechanics and they weren't sure if it's normal or not.
When only one fan is on (a/c off or a/c on but compressor off ??), the temp can go up to 92-95 degree C (probably closer to the end of 0 on you 180 mark), technically not overheating yet, when both on, the temp is only about 82-85 C).
Is your temp similar ?
Please let me if you do get both your fans to come on at low speed with a/c off. My series resistor should be arriving sometime next month, so will only be installing it then. Will let u know if that changes things.
Replaced the resistor and the problem is gone. also, claening the radiotors and condensers made a huge difference in loweing the coolant temp.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
