Old 06-16-2011, 08:11 PM   #1
Appreciate your response and will try unplugging the MAF. Although I am relatively confident that its ok.
I have cleaned the MAF with proper CRC MAF spray which would remove all oil. Plus from what I hear, a new maf is less than $70US if you buy outside of porsche.
BMC is probably the world's top brand of air filters, especially for exotic cars. This filter outflows the stock piece easily and with my all carbon intake piping sealing off to the side vent, the inlet temps will not have increased at all. They should in fact drop due to the better thermal properties of carbon over plastic.
Sam
sparker is offline   Reply With Quote
Old 06-16-2011, 08:27 PM   #2
there is a way to test the MAF device itself. You need a voltmeter, and a 12 volt power supply. Basically you are testing the connections, then you blow air across it, it will read out on voltmeter if good, and if you tap on it and it changes output, it is bad.
That is the idea, someone else will have to fill you in on specific methods. I found it easier to just replace it, and see.
Cleaning it does not matter, if it is going out the hair thin platinum wire is damaged or worn out. The fact that you said it ran much better with the computer reset is telling.
Do you have any codes?
2002 S
jhandy is offline   Reply With Quote
Old 06-19-2011, 05:06 PM   #3
Hi,
took the sensor out and gave it another clean on the weekend and then followed it up with a nice country drive of about 60km. (Lately I have only been doing the cold short trip to work and back - about 4km each way, car barely heats up) And it seemed to have helped quite a lot. Also put some fresh fuel in it as the last tank lasted probably about 2 or 3 months.
Car certainly liked the open road and getting up to temperature and may have helped the issue. Ran much nicer this morning on the way to work, still a slight hesitation though. Think I might order a new MAF to try anyway.
Regards,
Sam
Old 06-19-2011, 05:09 PM   #4
oh - and no codes, but its still not 100% right.
Sam
Old 06-20-2011, 02:52 AM   #5
Sam - I had the same issue(s) as you and ended up removing the entire throttle body assembly and deep-cleaned it. I've used "circuit board cleaner"... strong stuff and doesn't leave any residues. There is a valve in there (forgot the name of this one) that also need deep cleaning. Just make sure each parts of the assy is well cleaned and put this all back together and you'll have a brand new car bro.
After 10 years, mine was dust-oil-greese-bugs-****************e infested. It was very embarrasing to see.
While at it, you may also want to clean the airbox and conduits. Lots of ****************e residing there as well.
MAF, air filter goes after doing above.
Hope this helps
madmods is offline   Reply With Quote
Old 06-20-2011, 02:54 AM   #6
here goes some visuals if you are the DIY kinda guy
http://www.pelicanparts.com/techarticles/Boxster_Tech/28-FUEL-Throttle_Body_Cleaning_-_Boots/28-FUEL-Throttle_Body_Cleaning_-_Boots.htm
Old 06-20-2011, 05:03 AM   #7
I had the same issues, my solution was a new MAF, and new O2 sensors. Unfortunately, this can be expensive since the sensors are like 60 bux or something like that.
Old 06-20-2011, 04:20 PM   #8
I did clean the throttle body and intake tube about 10 months ago, but could take a look at it again. I actually have a spare throttle (an entire intake manifold) that I could use as well. I don't think that will be the problem though as its not just a rough idle, but more of a low air speed stutter (take a slow corner and when you accelerate out of it, then engine will stutter).
I've ordered a new MAF as this is something that I have not changed since getting the car two years ago and have no idea just how old it could be. After hearing the good reviews of ebay sensors, I have purchased a $89 one from the same seller that others here have used.
I might also invest in a second wideband sensor and also re-calibrate my other wideband (have one on the right bank and the stock sensor on the left) to ensure they are reading correctly. Innovate LC-1's are similar in price to the stock oxygen sensors and can do oh-so-much-more!
Hopefully then, she will be as good as new!
Sam
