Old 06-03-2011, 01:47 PM   #1
thefatbassplayer's Avatar
Squeeky Steering after Spring Replacement
Hi Need some advice...
My 00 Boxster failed its MOT on a broken OSF road spring...
I had both springs replaced as a matched pair.(genuine)
What's the Problem?
Since the springs have been replaced I have inherited a Steering
squeak after about 25-30 miles... (once the car has warmed up)
I have taken it back to the dealer and they say they can't find anything wrong
I was also told that it takes a while for the suspension to settle after spring
replacement and if I gave it a few hundred miles the noise should disappear...... Is this true?
I Thought if anyone knew if this was the case it would be you guys!
Regards
Andy
thefatbassplayer is offline   Reply With Quote
