Old 05-31-2011, 12:35 PM   #1
smoking and loss of power
Hi everone..I have a 98 Boxster and have just completed putting her back together, I took her over the local airstrip for a test run and stumbled on a problem.
While giving her a bit of stick on left lock the car bogs down on power then chucks out loads of smoke (not from the tyres) , On right lock it's sweet and runs perfect.
I was just wondering if anyone had any idea of the cause of the problem or if thay had herd of a problem like this before....Many many thanks
jell is offline   Reply With Quote
Old 05-31-2011, 01:21 PM   #2
Aos
The AOS is getting overwhelmed on left had turns, and puts oil down the back of the throttle body
goldsc_78258 is offline   Reply With Quote
Old 05-31-2011, 01:37 PM   #3
Thanks but Whats AOS and were is it? Cheers
Old 05-31-2011, 01:57 PM   #4
Aos
It is air oil separator and is on the driver's side of the engine if you do a search you'll be able to read a lot about them
Old 05-31-2011, 05:46 PM   #5
Jager's Avatar
The AOS is on the driver's side if you live in the UK... Your post messed with my mind for a second.
Jäger
300K Mile Club
Old 06-01-2011, 06:19 AM   #6
Thanks ever so much guys, I will get one ordered and replace. Big thumbs up
