Old 05-05-2011, 12:22 PM   #1
Drivers Side Rad. Fan not Working
Hello!
I'm hoping someone can help out with some possible causes/fixes for this..
it seems as though my drivers side radiator fan does not work.. the only one I ever feel come on (when running & when i turn AC on) is the passenger side one..
based on what i've read on the forums.. the only thing I can figure on my own is it might be the relay and i'll try switching it with the passenger one and see if that helps..
but .. i have no idea what im doing so if anyone has any suggestions.. pleasse let me know!
thanks,
Richard
rwgottar is offline   Reply With Quote
Old 05-05-2011, 12:40 PM   #2
There is also a small resistor mounted by the radiator that craps out, but can be changed without too much hassle.............
Old 05-05-2011, 01:10 PM   #3
thanks! i'l be sure to check that out.. any idea where i can pick one up?
Old 05-05-2011, 01:14 PM   #4
ppbon's Avatar
At the dealer, or online.
Happy Boxstering,
Pedro
Racecar spelled backwards is: Racecar!
ppbon is offline   Reply With Quote
Old 05-06-2011, 05:13 AM   #5
thanks guys, switched around the relays and they all seem to be working.. so i guess the resistor is the next in line..
im assuming I need to remove the front bumper to get at the rads?
