Old 04-03-2011, 01:02 PM   #41
Engine Surgeon
Its in a legal holding pattern at the present. The technology is already developed and we are awaiting the legal protection before sharing any details or applying the kits outside of "testing".
I'd expect 6 month. We want it before that, but thats the reality because we can't push this and get the protection it deserves.
US Patent 8,992,089 &
US Patent 9,416,697
Old 04-07-2011, 06:56 AM   #42
Just to add another engine
My 2004 S Anniversary Issue Tiptronic died in Oct. of 2007. I had it for about two years and 4 months with 12,765 miles on it.
It gave me two warnings. It stopped running in the rain with heavy puddles on the interstate while in cruise. I was baffled and thought the cruise didn't like the wheel slippage. It started up and ran on for several more hours with no problem. The next morning when I started out to Petite LeMans it had a metalic clicking noise when idiling cold I just thought it was the cooler weather and went on. About 5 minutes later it died on the interstate to not start again. No Explosion and very little noise. The dealer in Atlanta said it had no compression. I figured the chain had given up or slipped off. The whole thing was covered by the warrantee. A new anniversary engine was flown in and installed. I was never told what the problem was because the dealer couldn't open the engine. It has been said that the replacement engines are bullet proof. I don't know about that but it might have an IMS bearing upgrade because it was 2007 when I got it.?
I then noticed that the new engine ran much smoother. I hadn't noticed a slight vibration before.
Now 16,000 miles more I will make more frequent oil changes. I drive it like a stick and used to down shift for lights, curves, etc and use the engine to help brake. I don't do that anymore, but have a lag problem if I let the Tip do all of the shifting.
Just recently I've noticed oil smoke sometimes when I start up. I don't know what's causing that but will have to have it checked out.
It seems to be always something. I really think Porsche has some exposure to these problems.
Terre
Originally Posted by seningen
Earlier someone mentioned that it must have been heard, look at the damage.
I could be wrong -- but it doesn't take long to create carnage when you have metal on metal.
It is possible that the majority of the damage was caused when the bearings
finally let loose.
I'm hoping that there is a method to see the failure before catastrophe.
However the only way I can see that happening in a realistic fashion
is hope for an audible alert -- and frankly those engines make so much
noise that I doubt you could isolate it consistently.
One other possibility is diligent oil analysis, looking for some tell tale sign.
Again, I'm not sure its the proper canary.
Mike
Terre Higgs is offline   Reply With Quote
Old 04-07-2011, 03:20 PM   #43
A little smoke on start up isn't too unusual...maybe you just hadn't noticed it before?? Since it's still under warranty, your plan to get it checked out might be the best way to go.
BTW---Driving in cruise when it's raining isn't really a great idea, especially if there's much rain water accumulating on the highway.
Old 04-07-2011, 04:42 PM   #44
Uh oh
Old 04-07-2011, 05:03 PM   #45
Engine Surgeon
No, thats not bad.. We are working onpatents and trademarks and won't release anything until the property is protected.
US Patent 9,416,697
Old 04-08-2011, 04:43 AM   #46
No that IS bad
the last patent I got took a year and tens of thousands in lawyers fees and I did most of their work.
Old 04-08-2011, 04:56 AM   #47
Engine Surgeon
Yep, but its simply required for this technology and you'll see why when its released. I have a good group to work with on this and the cost won't be that extreme. We are expecting the provisional patent any day now and that will supply us with the required protection while we finish up the rest of the BS.
Our first run will be 1500 systems, I expect them to fly off the shelves.
US Patent 9,416,697
Old 04-08-2011, 07:15 AM   #48
Will it apply to TIPs as well as Stick?
One time use or install and monitor?
Old 04-08-2011, 07:50 AM   #49
Engine Surgeon
All details later. You'll be one of the first to know.
US Patent 9,416,697
Old 04-08-2011, 12:55 PM   #50
Me second!
Old 04-25-2011, 11:18 AM   #51
... Hell, I can't believe that no one has made any smart ass statements about or most recent Excellence Ad.
Is Boxster still spelled "Boxtser" in this month's ad? I've been hoping you'd get them to fix that, one of these days.
My car, with it's Raby IMS Retrofit, is still running strong, by the way. I already have 2 track days scheduled in May, and another one in July.
2002 Boxster S, 6 speed, Speed Yellow
Flat Six Innovations 3.8L Stage II Track Performer, RoW M030 Suspension, B&M Short Shift Kit, Fabspeed Bypass Pipes, FVD Brombacher "Sound Version" Muffler, UD Pulley, Low Temp T-Stat.
Banana S is offline   Reply With Quote
Old 04-27-2011, 12:38 PM   #52
Engine Surgeon
Thats great to hear!!! It has a had a recent Birthday, has't it? LOL
US Patent 9,416,697
Old 04-27-2011, 08:07 PM   #53
IMS victims please complain to NHTSA
My apologies if you’ve seen this posting in other forums. I’m trying to raise awareness of this subject.
I have an 04 Boxster that had confirmed IMS failure last week at 58K miles. Dealer employees, including service managers, have admitted to me that they have a significant number of IMS failures in this engine, and didn’t deny that it should have been a recall. I didn’t know of this defect until it (probably) happened to me, and feel angry that Porsche sold me a car without revealing a fatal design flaw (sealed bearing with seal that fails in normal use, then relying on inadequate lubrication from crankcase oil splash).
When I called Porsche (1-800 Porsche), I was told there was no recall for the IMS defect because “the government orders recalls and they didn’t order a recall” for the IMS issue. Recalls are triggered by complaints to the NHTSA – not very many complaints, no recall. NHTSA complaints and investigations can be researched at their website: http://www.safercar.gov/Vehicle+Owners . Between MY 2000 and 2005 there were only 6 IMS failures reported with std or S Boxsters. Brief internet searches reveal that the actual failure rate is certainly much higher than these numbers would suggest. Complaints can easily be filed at the NHTSA website. If everyone with IMS failures went to the NHTSA website and filed a complaint, perhaps an investigation and thus a recall might be triggered. I’m not sure if a recall could be ordered for cars this old, but at least the relevant government agency should adequately notified. If the government took action, Porsche would be forced to respond.
dmatz is offline   Reply With Quote
