Old 03-29-2011, 05:14 AM   #1
How do I adjust the shift linkage?
I just changed the clutch and once it was all together REVERSE gear was very difficult to engage. I thought the adjustment was the connectors that are under the center console but after I did that I can't get REVERSE at all.
How do I adjust then? I have all other 5 gears and was able to drive it around the block last night when I had reverse.
Chris
87 944S brought back to life
Dragonwind is offline   Reply With Quote
Old 03-29-2011, 08:11 AM   #2
Red face
Oh I see the bolt on the transmission side to make the adjustment...duh!
Old 05-07-2013, 04:09 PM   #3
CoBeerToad's Avatar
Well. He kind of left me hanging there didn't he? I encountered the exact same problem. I'm done for today. Guess I'll look around on the side of the transmission. Any help would be appreciated.
CoBeerToad is offline   Reply With Quote
Old 05-10-2013, 02:02 AM   #4
My car is a racing car and as such not stock - I have a 2001 Boxster s with an early 5 speed box.
One of the projects that I did over the winter was to replace the bent and rusted shift linkage on the transmission to a nice new one. After the change I found I could no longer engage reverse.
Turned out that I had to lower the linkage a fraction - put a washer between the shift linkage and the transmission (two bolts under the transmission that mounts the linkage to the box) - and I could then get reverse again.
Not sure if this will solve your problem or not?
Kroggers...
"Trying to drive a Boxster S for team CoolCava Racing!"
www.coolcavaracing.com | www.paulkrogdahl.com
Kroggers is offline   Reply With Quote
Old 05-10-2013, 02:11 AM   #5
Kroggers...
Old 05-10-2013, 04:11 AM   #6
CoBeerToad's Avatar
Sorry. Already solved it in the General Discussions page. I had a linkage turned upside-down. Thanks though.
Old 05-26-2023, 07:40 PM   #7
Are you referring to the circled bolt in the attached image? I’m having a similar problem after swapping cables and am desperately searching for answers.
986Pcar is offline   Reply With Quote
