Old 03-27-2011, 09:14 PM   #1
Crazy Austrian
harryrcb's Avatar
Another IMS issue 04 Boxster S
Here is another statistic for the IMS failure. This is an 04 Boxster S Trip with less than 35k on the odometer. The owner Hung Vo from Texas was filling up gas when he noticed a puddle of oil under the car. Unfortunately he drove it home which was not far. Miraculously he made it, that's when he called me about my engine. So we made a deal and shipped the car to my place and this is what I found. Motor still turns over (by hand) but you can feel the valves touching, barely. the oil filter and the bottom of the pan were just thick with metal shavings. Have not taken the bearing out yet, I will swap engines first and get poor Hung going again, then I will tear apart the engine and see how much damage there is. BTW the nut and what's left of the shaft is exactly where I found them when I pulled the transmission.
[IMG]ppp.jpg[/IMG]
[IMG]ppp8.jpg[/IMG]
[IMG]ppp.jpg[/IMG]
Crazy Austrian 007
http://www.ws-ab.com
harryrcb is offline   Reply With Quote
Old 03-28-2011, 04:51 AM   #2
horrible! what a POS design.....
insite
'99 Boxster
3.4L Conversion
Old 03-28-2011, 06:38 AM   #3
Crazy Austrian
harryrcb's Avatar
Not what you would expect from German engineering !!!!
Crazy Austrian 007
Old 03-28-2011, 10:05 AM   #4
Engine Surgeon
Why do people do this!! If you hear a noise or see oil STOP!!! Do not start the car again!
We could have saved his engine if the engine wasn't re-started.
NO NOISE IS GOOD!!! NO LOSS OF OIL IS GOOD! If you see either STOP, SHUT OFF THE ENGINE and call the engine failure hotline!
US Patent 8,992,089 &
US Patent 9,416,697
Old 03-28-2011, 11:25 AM   #5
I just noticed I have a small leak on mine. It appears to be from the transmission/motor area. Gonna pull the tranny when I get a chance. I pulled the oil filter housing and all looks good there. No metal or the like. I think it might just be the rear main oil seal.
Hawkeye71 is offline   Reply With Quote
Old 03-28-2011, 12:15 PM   #6
Really makes me feel good about spending the money on the LN/Flat6 IMS retrofit!
smcgeary is offline   Reply With Quote
Old 03-28-2011, 12:47 PM   #7
tnoice's Avatar
Jake, I also do not understand why if someone has a car that is injured, they limp it home. CALL A TOW TRUCK! If you break your leg, while jogging, do you stop and call for assistance or do you continue to run home on your bumb leg?
sorry, just my $.02
Lov'n my boxster!
2013 Lexus IS350awd
2007 Toyota FJ Cruiser
2004 Porsche Boxster S
tnoice is offline   Reply With Quote
Old 03-28-2011, 01:24 PM   #8
Carnut
AndyA6's Avatar
In all fairness..... if one does not know any better.... BUT should have known, I guess.
Not all people know about engines/mechanics etc., just look at your kids, neighbors and so on!
'14 Boxster
Old 03-28-2011, 08:32 PM   #9
Crazy Austrian
harryrcb's Avatar
I don't think the owner knew at the time what the consequences could be. He learned about the IMS after the fact. I guess not everyone can be mechanically inclined..
Crazy Austrian 007
