Old 03-25-2011, 11:50 AM   #1
Carnut
AndyA6's Avatar
Question How much does the stock ECU adapts to mods??
I am not sure about this.
Let's say I put in an intake, 2ndary bypass pipes and an underdrive pulley. Will the ECU after a while adapt to the new hardware?
Thanks for sharing your thoughts, insight and expertise!
'14 Boxster
Old 03-26-2011, 03:54 AM   #2
Rennzenn
j.fro's Avatar
You are most likely safe. If you want to know for sure, get an air:fuel ratio reading done. Most shops with a dyno can do this.
Old 03-26-2011, 04:04 AM   #3
yes it will adapt but it will take approx 30-50 miles to "learn" and then maybe some - akin to disconnecting the battery. Though it should be minimal, be prepared for feeling some loss of power and/or stumbling during this time - it's normal.
Good luck
Old 03-26-2011, 06:37 AM   #4
Carnut
AndyA6's Avatar
Thanks guys!
'14 Boxster
Old 03-27-2011, 11:22 AM   #5
How did you not notice the exact same post with almost the exact same title a few threads down?
Just saying.
mikstew is offline   Reply With Quote
