Old 02-19-2011, 01:43 PM   #1
fault code 48
The airbag warning light on my 2001 boxster recently came on and has stayed on. I have plugged in a diagnostic cable with durametric software and under the ALARM section it reads CURRENT FAULT CODES- 48 AIRBAG SIGNAL ACKNOWLEDGED. I am unable to clear the fault code. Can anybody give me any ideas on a fix.
HOUSTONBOXT is offline   Reply With Quote
Old 02-19-2011, 02:13 PM   #2
If memory serves, that is one of the codes for the seat belt ground wire fault problem. There was a TSB out for it that required updating the wiring on the seatbelts. The code will not clear because the problem has not been fixed. Do a search as this has come up several times on multiple boards……….
Old 02-19-2011, 04:58 PM   #3
You can get a hint of what to do from
https://sites.google.com/site/mikefocke2/airbagwarninglighttsb
Old 02-22-2011, 05:03 PM   #4
Thanks for the help guys. Will try cleaning the connections under the passenger seat and will be ordering the service seat buckle kit as per the TSB.
