Old 05-24-2005, 07:52 PM   #1
Send a message via AIM to St. Louis Boxster
Exhaust smoke on start up
I've got an 04 Box, not an S, and after the car sits in the garage for a couple of days I get a significant amount of smoke out of the exhaust on start up. It goes away quickly, like by the time I back up into the street. The oil level is fine, the car has 8K miles. Recent;y 2 months ago, I had a seal replaced on the rear end that was causing some oil drips on the floor.
Any Boxter forensics out there?
Gus
St. Louis Boxster is offline   Reply With Quote
Old 05-24-2005, 08:31 PM   #2
Very common on these cars. I forget why but most if not all Boxsters do.
JP-s-in st. louis is offline   Reply With Quote
Old 05-24-2005, 10:16 PM   #3
Send a message via AIM to phrankandbeanz
very normal to see big puffs of white smoke on startup every once in a while
phrankandbeanz is offline   Reply With Quote
Old 05-25-2005, 04:10 AM   #4
Thanks guys. My mind is at ease.
Gus
Old 05-25-2005, 06:38 AM   #5
Re: Exhaust smoke on start up
The 986 faq.com website has this info. on start up white smoke:
The Boxster engine uses a flat six cylinder design. Because of this construction, oil residue remains under the piston heads and burns off at every start up. This can produce a white puff of smoke. It should only lasts a few seconds. This is normal, and no correction is necessary.
Bachster is offline   Reply With Quote
Old 05-25-2005, 06:38 AM   #6
Brucelee's Avatar
Talking
Totally normal. The 911s do the same thing!
Old 05-30-2005, 11:18 PM   #7
Mind now at rest
Had noticed the same from our 00 S and wondered why
Aussie2000S is offline   Reply With Quote
Old 08-07-2005, 03:49 AM   #8
Send a message via AIM to G3sys
my 05 just did it yesterday.
G3sys is offline   Reply With Quote
Old 08-07-2005, 06:04 AM   #9
Brucelee's Avatar
Talking
Good to see they didn't engineer this fine feature out of the 05!
Old 08-08-2005, 12:28 PM   #10
Ronzi's Avatar
Both my old 911 and the '99 Box smoke on startup. The 911 frequently, and the Box upon rare occasion.
The horizontal opposed cylinder configuration is frequently offered as an explanation, but answer me this ...
I have had two different VW beetles with opposed 4s and never had anything like the same smoke issue, nor have I heard of people with Subarus (also opposed 4cyl) having smoke on startup. This seems to be a phenomenon pretty much restricted to Porsche 6cyl. Even the old 356 4 cyl didn't do it, as far as I know.
I don't get it, really.
Ronzi is offline   Reply With Quote
Old 08-08-2005, 01:10 PM   #11
Maybe its the 0-40 oil, as its very thin...
Mike
99-Boxster-MK is offline   Reply With Quote
Old 08-08-2005, 01:20 PM   #12
Brucelee's Avatar
I don't think it is the oil. Actually 0-40 is NOT thin but is a full 40 wt oil.
Moreover, I have used 15-50 in my 911s and they still do this!
