Re: Exhaust smoke on start up
The 986 faq.com website has this info. on start up white smoke:
The Boxster engine uses a flat six cylinder design. Because of this construction, oil residue remains under the piston heads and burns off at every start up. This can produce a white puff of smoke. It should only lasts a few seconds. This is normal, and no correction is necessary.
