Old 01-07-2011, 05:16 AM   #1
The silver box is the ballast which supplies power to the bulbs.
If both left & right bulbs are not turning on I doubt it's the bulbs. Check the fuse which is in the fuse box and it could be the light switch that could cause this as well.
Get yourself the Bentley manual if you do not already have it.
Old 01-29-2011, 04:03 PM   #2
Bentley manual not much help?
Basically all the bently manual says is to swap out left side for right side parts to find what is not working. Won't help me as both sides do not work. Driving lights, parking lights and high beams work. I have another ballast ignitor from aftermarket compatible lights that will not work so I have determined that it is in wiring or switch. I have checked the fuses and everything else. High beams dip and everything else works.
What is not working is dash switch works when you turn to parking light position, but does not work when you switch to headlights, pull out and driving lights work and rear driving light works.
High beam stalk will work high beams if you pull it back, however if you push it forward to detent position as if you were driving on country road and not seeing traffic and wanted to lock them on the high beams go off? Not sure if this is normal?
So instead of checking for broken or bad wiring I am going to assume it is switch in the dash and order that?
just wondered if anybody else had just one function on switch go bad?
IndyGreg is offline   Reply With Quote
