Old 01-01-2011, 08:55 PM   #1
Non-S shifter and cables in S
Will the entire Shifter with both cables attached work as a direct replacement.
2003 Boxster (non-S) 5 Speed
Part: Complete Shifter with both cables attached
into
2003 Boxster S 6 Speed.
and if not, Why?
Ryan
2003 Boxster S
2K3_Boxster_S is offline   Reply With Quote
Old 01-02-2011, 10:46 AM   #2
Normally the easiest way to replace a shifter is the complete shift tower, without the cables, which stay attached to the tranny. (Mods like the B&M shifter upgrade require rebuilding of the tower.)
The cables are removed from the old tower, the tower is removed, the new tower is installed, the cables are put back into the tower (with centering tool on the shifter), and you're off to the races.
The stock shifter towers work on both the 5-spd and the 6-spd.
I installed the 9x7 short shifter tower in my 986, and love it.
clickman is online now   Reply With Quote
Old 01-02-2011, 06:46 PM   #3
I already have a schnell short shifter installed, so I am familar with the hacking up of the stock shift tower. which is why I bought an entire used tower with factory shift cables attached. I can't use my original tower or cables since I modded with the schnell short throw shifter since one of the cables was mangled due to the short screws "grabbing onto the shift cables" type set up schnell uses.
I loved the Schnell shifter as well. It's just a fact that any mod is going to de-value the market value. Boxster buyers are looking for untouched cars.
So I think you did answer my question the tower and cables should be the same I hope.
RYan
2003 Boxster S
Old 01-02-2011, 11:29 PM   #4
I don't know if the cables are the same for the 5 and 6 spd. Sorry.
Old 01-04-2011, 07:19 PM   #5
Spinnaker's Avatar
The parts diagrams on the AUTOALANTA site show 9 cables for the shifter. Someone with more patience than me, can figure out which one is which and what it will fit.
http://www.********************************************.com/porsche-parts/986-97-04/701-00.php
