Old 12-13-2010, 05:17 PM   #1
BYprodriver's Avatar
With trans in neutral pull shift cable off the reverse shift lever (short one) now see if you can engage reverse with the short shift lever alone. Should be able to shift back & forth & fully engage reverse gear. If so return shift lever to neutral (half way between full left & full right & snap cable back on.
Old 12-14-2010, 03:06 PM   #2
Cheers i'll try that tomorrow and let you know.Thanks
jell is offline   Reply With Quote
