Old 11-14-2010, 09:55 AM   #1
Flashing CEL '98 986
I just changed my oil/filter (15w-50 warm SoCal climate) and my spark plugs. The car started up nicely, but after idling for a while, the CEL light came on. This has happened before, so I assumed it was a cold misfire or a loose gas or oil cap. I went for a drive, and noticed less power, less of a smooth sound (engine was not quite warmed up). I drove about 300 yards and the CEL started flashing. PANIC! I parked, scoured service manual, then restarted car. Same events. Solid CEL when parked, flashing at about 30mph. Then the car reached operating temperature and started running smoother and the CEL went solid (not flashing). I'm completely stumped. (though i think my thermostat needs replacing, as it takes 15 mins to warm up).
help? anyone?
macyfilms is offline   Reply With Quote
Old 11-14-2010, 10:04 AM   #2
With out getting the codes scanned, anything would be purely a guess. A 986 with a flashing CEL means "park it and get it towed to someone that knows what they are doing........." Get it flat bedded to a shop that can scan it...........
Old 11-14-2010, 10:28 AM   #3
Listen to JFP
and don't drive it or run it. The flashing CEL and the solid-on CEL are different and flashing is something SERIOU$.
Old 11-14-2010, 02:01 PM   #4
flashing cel
It appears I can't borrow a code reader in California. The stores won't lend them out. I'm thinking of buying one of the Actron scanners for $149. (the 9180) Any opinions on this? My only other option is to tow it to a dealer and you know how they're going to treat me there...
Old 11-14-2010, 02:39 PM   #5
Steve Tinker's Avatar
The Actron (or Durametric) may cost you $150 but its a tool well worth investing in. At least you can get the fault code read and then start to diagnose what the problem is. Could be something simple or something serious.
Right now you are guessing & have 2 options - drive the car with possible engine destruction or take it to the dealers while dropping your pants.....
2001 MV Agusta F4.
Old 11-14-2010, 02:40 PM   #6
Idaho Red Rocket 3's Avatar
Flashing CEL
Sears. $50 and up.
Old 11-14-2010, 02:42 PM   #7
Actron makes good stuff, but I think the 9180 is a discontinued model......
Old 11-14-2010, 03:34 PM   #8
If I were gonna buy a code reader
for that $150 list money it would be the 9575 . Amazon at ~$115
Good enough at the list $100 price point is the 9550 Amazon ~$67
None of the code readers are as capable as the Durametric (s/w for the Windows Laptop and cable) or the Porsche computers the dealers use (PST2 and PWIS).
Anyone in the area you can borrow from? Fellow Porsche owners? Other car club members?
good luck.
Old 11-14-2010, 03:57 PM   #9
Got the cheapest one at Amazon (US$19). Works fine, delivered next day.
Leo
2002 Boxster S - Meridian Metallic
mcfly777 is offline   Reply With Quote
Old 11-14-2010, 05:41 PM   #10
codes !
Thanks guys. I borrowed a reader and here is what came up:
P0306 ; P1125 pending; P1123 pending.
I just changed the plugs, so I am guessing i must have screwed up one of the coils (#6 ?). Prior to the plug change, i did not have any codes.
Thoughts on how to proceed?
thx.
Old 11-15-2010, 03:47 AM   #11
The 1123/1125 are the worry
because they say both banks are being affected.
For the 306, sure look at the wiring, coil and plug for the 6th cylinder. Wires reversed with another? Coil on tight to plug? Plug looks like? Coil cracked? Switch coil to another cylinder and does the problem follow the col pack???
For the 1125/1125...do anything to the intake area? Why is everything (both banks) running lean? Too much air. MAF disconnected? or just cleaned? Leak in intake somewhere?
What kind of air filter? Just replaced?
Old 11-15-2010, 04:39 AM   #12
jcb986's Avatar
Had a cel throw after changing plugs. One of the coil packs did not seat and was just making contact. The rubber caps/protectors can cause the coil wire not to connect even though you think you have it seated.
Old Hippie Young Heart
Old 11-15-2010, 08:29 AM   #13
We can just stop you right there.
No need to go any further at all.
Get back under your car, disconnect all the wires from the coils, remove the coils from the spark plugs, plug the coils back onto the plugs FIRMLY, and then snap the wires back onto the coils FIRMLY.
One or more connection is loose.
In my experience, when a problem comes up so soon after performing work on a car, at least 80% of the time, the problem is related to the work that was done.
BC.
Its not how fast you go, or how expensive your toys are.
Its all about how big your smile is at the end of the day that truly matters.
'98 Silver Boxster, '08 Ducati 848, '89 Honda Hawk GT, '89 Honda Pacific Coast
Bladecutter is offline   Reply With Quote
Old 11-15-2010, 09:19 AM   #14
What kind of air filter? Just replaced?[/QUOTE]
I am assuming the #6 coil didn't get reattached properly so i'll look at that. (is that driver's side, rear cylinder?)
on the 1123/1125, i'm stumped. i didn't change air filters or go anywhere near the intake. two questions on this? 1) is it possible that my bad thermostat is a factor here? it takes eternity to warm the car up. 2) the readings from the scanner were "pending". is it possible that it was a one-time problem?
Old 11-15-2010, 09:21 AM   #15
BC.
BC, I agree. my greater concern is the 1123/1125 reading. i don't know why that is suddenly coming up. I'll snap the coil connection as you suggested. It's unlikely and oil change would impact anything like that, right?
Old 11-15-2010, 09:32 AM   #16
fix first code first 0306 its a hard code. clear the code and road test and check for codes. the pending maybe history codes
extanker is offline   Reply With Quote
Old 11-15-2010, 09:50 AM   #17
sounds like a plan. I cleared the codes. I'll re-connect the coil and see if i get the 0306 again.
Old 11-15-2010, 10:00 AM   #18
#6 is drivers side rear in some countries
picture of cyl layout
Old 11-15-2010, 08:33 PM   #19
i cleared the codes and let the car warm up before driving. After a 20 minute/ 22 mile drive, the 0306 code did not reappear, so I am assuming this was an isolated incident and was the cause of the flashing CEL.
but i did get PENDING codes 1123 1125 1128 1130. no CEL, but four codes showing both rich & lean issues. i'm stumped (as usual). Is it a risk to drive with these codes ? Or was it just the 0306 that was risky?
Also, I'm wondering if the cause might be A) 87 octane gas ? B) the car takes forever to warm up because of bad thermostat?
sg
Old 11-16-2010, 04:23 AM   #20
a pro repair maual and a good scan tool are needed so you can follow the diagnostic repair tree. a code reader is sometimes a teaser. a no cel means you can drive it but it seems you have other issues....gas,stat,soft codes and other surprises
