11-12-2010, 07:13 AM
#1
I don't think the OP has straight pipes all the way like the guy in that video, he says he kept the cats, just eliminated the muffler. I'm sure it's still very loud, but if he has all four cats they will reduce the sound somewhat.
Usna, any progress on that sound clip?
01-15-2011, 03:45 AM
#2
muffler delete
I did this mod last week and I thought I would give the results. I had the local muffler shop remove my stock muffler and make the new pipes. He used 2.25 dia. pipe. My cost was 160.00 total. I left the shop and it was a bit loud. Also there was an irritating drone from about 2K to 3.5K. I was expecting this but had never experienced it. I ordered some baffles from the net and installed them. They were cheap, about 15.00 shipped, they bolt in. They were 2" x 8" and worked nicely. I had to get the muffler shop to weld a spacer on the end for a nice tight fit, $5.00. The baffles seemed to eliminate some of the drone. I also ordered some heat proof fiberglass wrap from the net, 15.00 shipped, but did not like the result. I am presently using just the plain baffle, no wrap. I had it out last night and it is coming along. I might try using a small amount of wrap just to see about the results. I do think the baffles will allow me to get it inspected for the street. My main reason for the mod was to loose the weight more than make it louder. I haven't weighed the muffler yet but I would think I lost about 30 lbs. I might get chrome tips, they are on the net for $25.00, but I haven't finished tinkering with the setup yet. Total cost about $200.00. If anyone wants any pics I will try to accomodate, just send me your email address. Bill, Pgh, Pa. 99 Box.
01-15-2011, 11:15 AM
#3
Forget pics, post a video!
01-15-2011, 01:54 PM
#4
:dance: :chicken:
01-15-2011, 02:41 PM
#5
Its astonishing to see how some members take a "bubblegum and chicken wire" approach
to modifying (or should I say destroying) their exhaust . In view of the fact that Porsche spent considerable time designing their system, by the same token it requires a methodical approach to changing or modifying it . The irony in most of these cases is, that not only has power probably been lost, but engine reliability has likely been compromised as well.
01-16-2011, 02:49 AM
#6
With all due respect I think you missed the point of my post. I was trying to lose as much weight as possible and I think that was accomplished. Since the first post I weighed in the exhaust components and they weighed 38 lbs. The new piping can't be anymore than 5/6 lbs. I will gladly take the 32 lb difference and see how the car performs. My goal for this season is to drop 150 lbs. for track purposes and I think I will be there. Muffler delete, spare tire removal, seat switch, battery switch, coilover install, sway bar switch and engine cover pad and carpet (14 lbs) should do it. As far as your "chicken wire comment" I guess I should have spent $2000 on a custom exhaust in order to get a heavier system with questionable performance. We all have different goals with our cars, my research has pointed me towards lightening the car as much as possible and that is the path I have chosen. It would be easy to follow with a few more comments, but I will take the high road with the hopes of meeting up with you at a track somewhere and getting an opprotunity to see whose car performs better. Bill, Pgh, Pa.
01-16-2011, 05:19 AM
#7
With all due respect right back at you, please go back and re-read your post . At no time did you explain that the premise of your "modification" was to reduce weight purely for the purpose of tracking your vehicle. Rather, it reads like someone who has set out aimlessly to adulterate their vehicle with no real goal or objective in mind . As far as meeting up at the track and comparing vehicles is concerned, I suggest that you bring plenty of bubblegum for yourself ! Good luck with your project.
