Old 10-16-2010, 02:04 AM   #1
Help water on floor
Okay folks im going outta my mind here , after a coolant dump i decided to investigate and found that my 2nd pressure cap was faulty and that my expansion bottle had a crack in it.
So while i was repairing the above i replaced with the help of a very good friend the complete clutch system and all rear cv boots and repaired and tested the bottle and fitted the new cap , so i fire her up for the first time and all is fine , she warms upto 80 degrees , i turn her off and alls good.
I then 30mins later put her back into the garage shut off to find water dripping from the drivers side rear wheel area again , but this is cold water , im now at my witts end any ideas please and thnx in advance.
Boxster 3.2s 2000 Artic Silver
sheep is offline   Reply With Quote
Old 10-16-2010, 10:30 AM   #2
Porscheectomy
Did you have the AC running?
Old 10-17-2010, 02:01 AM   #3
Steve Tinker's Avatar
Sheep - you may have air trapped in the cooling system and it's expanding and forcing coolant into the overflow.
There is a bleed valve located under the plastic cover below the oil filler / coolant filler caps. Open the D ring to its vertical position and run the engine for at least 3 or 4 heat cycles (or maybe a few days) of normal driving. This will expel any air locked in the system. Top up the coolant as required with the correct mix ratio.
2001 MV Agusta F4.
Old 10-18-2010, 09:46 AM   #4
Thnx Steve & Blue
yep ive been all over the underside today checking pipes whilst she was clear off the ground on 4 axle stands and running i took her upto and held 3k for ages bringing the temp up and shut her off with no leaks , so i reckon your bang on Steve i thought this was but have been running her for 2 to 3 times now with the same resulting drips.
Going to do a long run this week and see what happens will post here the outcome
