Old 09-13-2010, 12:26 PM   #1
brake fluid help
Hi Guys,
my service book says brake fluid should be change every two years. It was last replace about 3 years ago-10 000kms/6000miles ago with racing brake fluid.
Do I need to change it, regarding it is racing fluid and last a bit better than standard fluid. Secondly, can I use my durametrics to pluse the abs for bleeding?
thanks,
Rob.
de-snorkeled, clear lights, sports exhaust, zeintec hard top, zein wing, B&M short shifter, DesignTek lowering springs, DesignTek carbon fibre strut brace front and rear, 18'' carerra 5 spokes, semi slick tyres, entire soft top delete, engine cover delete,red console,L&N deep sump, volo performance chip, raptor shift light, de-cat'ed, OEM GT3 bucket seats.
sickbananas is offline   Reply With Quote
Old 09-13-2010, 12:30 PM   #2
Pat
I am under the impression true racing brake fluid needs to be changed MORE often than the normal stuff.
"Of all the extreme sports I've ever participated in- windsurfing, kite boarding, wake boarding, tow-in surfing and snowboarding- skiing, for me, made everything else easy."
-Chuck Patterson
Pat is offline   Reply With Quote
Old 09-13-2010, 12:46 PM   #3
Just use either Ate Blue or 2000 (same product, different colors), and unless you have let air into the ABS system, it does not need to be cycled while bleeding. Be sure to due your clutch (with the pedal held to the floor) while you are at it.
