Old 02-05-2003, 05:40 AM   #1
DIY shifter knob and brake lever installation
Dear Owners/Enthusiasts:
I own a 99 boxster and it comes with the ugliest black gear shifter. My interior is sienna beige and have come across some nice matching ones (beige and finished stell look) on eBay.
Just can't figure out how to install the sucker...
Please advice and thanks in advance.
PS: Same goes for the hand-brake lever.
jollyroger
jollyroger is offline   Reply With Quote
Old 02-05-2003, 08:05 AM   #2
You unsnapp the boot which is held in place by 4 plastic clips. Then just pull the shift knob off. Some cars require more force than others to pull off. Remove the center console to replace the brake lever. The brake lever is simply bolted in place. Unbolt the old and bolt in the new - and adjust the lever so that there are 5 clicks when you pull it up. Jeff
Old 02-13-2003, 06:00 AM   #3
Thanks Tool Pants
Thanks tool pants. It worked !
However, pulling out the old shifter almost caused me a double-hernia...that things tough as hell!
Best,
le jolir rogue
