Old 08-12-2010, 05:36 PM   #1
Need help with engine error codes on 99 boxster
I have the following engine error P-codes:
P0102 (Mass air flow sensor, short to ground/below lower limit/ lean mixture threshold)
P1124 (fuel pump relay output stage, short to ground/below lower limit/lean mixture)
P1126 (oxygen sensing adaptation, lower load range, cyl. 1-3, short to B+/above upper limit/ rich mixture threshold.)
I would be immensely grateful to anyone who has ideas on where to start. Thank you soooo much!
Colby
99 2.5L Boxster: 135,800 miles, AVIC-Z2 In-dash navigation/DVD receiver w/bypass switch, made and installed Pedro's hi flow air intake, custom laser engraved wind-stop, hacked convertible top relay, de snorkeled.
Pianohawk is offline   Reply With Quote
