Old 08-03-2010, 11:18 AM   #3
got it
I figured it out…you have to remove the entire peddle assembly..Not difficult, 1 screw and pull up and out, then you push a small flat screwdriver up the back end and it slid right off.
The other instructions online showed installing under the dash, but this (once I figured it out) was a 2 minute install.
shmelvin is offline   Reply With Quote
