Old 07-26-2010, 03:05 AM   #41
Engine Surgeon
Looks like oil smoke to me as well.
I bet you have a bad AOS right out of the box, they can be intermittent.
US Patent 8,992,089 &
US Patent 9,416,697
Old 07-26-2010, 08:34 AM   #42
Jake, that would be 2 AOS in a row bad out of the box? I just don't think its the AOS. Im getting it back to him and he is going to pull plugs. Let you know what he finds.
anti-bling is offline   Reply With Quote
Old 07-26-2010, 09:33 AM   #43
Engine Surgeon
I've had customers get 3 bad AOS units in a row.
Disconnect the AOS and block it off and see if the issue goes away for troubleshooting purposes.
Don't drive it that way, just see what happens when the unit is disconnected and pay attention to the amount of oil in the intake plenum.
US Patent 9,416,697
Old 07-26-2010, 01:10 PM   #44
Started 'er up this morning... deffinately oil. Some even came into the cabin of the vehicle...well it is a soft top. Ill let you know what i hear back.
Old 07-26-2010, 02:00 PM   #45
Send a message via AIM to blinkwatt
Listen to him.
-99' Zenith Blue 5-spd...didn't agree with a center divider on the freeway
-01' S Orient Red Metallic 6-spd...money pit...sold to buy a house
blinkwatt is offline   Reply With Quote
Old 07-26-2010, 03:16 PM   #46
For what it's worth, I'm defecting out the new AOS I installed 1,000 miles ago. I still get the smoke whenever the car wants to...I keep getting oil in the "j" tube.
I'm also switching from 0w40 to 10w40 oil...
Good luck,
Kyle
Lupdiesel is offline   Reply With Quote
Old 08-06-2010, 11:23 AM   #47
Crazy Austrian
harryrcb's Avatar
I know that I am comming into this discusion a little late but guys, reallly, if it only smokes going up hill, then it cant be coolant. coolant is constantly at the same press according to your running temp.
Is it possible you or your bright mechanic overfilled the OIL you should be slightly under the top fill mark!
And if thats not it then it something in the AOS, maybe you need to replace the line to your left cyl head
Good luck with it
Crazy Austrian 007
http://www.ws-ab.com
harryrcb is offline   Reply With Quote
