Old 05-12-2010, 05:04 PM   #1
The Radium King's Avatar
the dreaded exhaust question (again)
hi there, i'm asking the dreaded exhaust question (again). i've seached the forum but can't find what i'm looking for.
i'm new to the boxster and new to this forum - hello everyone ...
i have a 2000 boxster s. i am looking to increase power; i intend to do the chip/intake/plenum mods and was thinking about exhaust. sound is secondary and exhaust components (typically) expensive.
questions:
1) it makes sense to me that a freer-flowing exhuast will reduce torque at lower rpm (less back-pressure) but increase hp at higher rpms when more air is moving through; is this valid?
2) the boxster s has a more tuned exhaust, and aftermarket exhaust will yield a smaller (if any) hp increase; valid?
3) where is most power increase found - header, sport cats, test pipe (secondary cat delete) or muffler? i could see headers being most beneficial, as more power would be seen through efficiency (equal length pipes)?
4) if i am increasing/improving airflow at the intake with improvements to the intake and plenum, would these benefits be increased with a freer-flowing exhaust (more are in, more air out)?
i quess i'm trying to drill down to whether exhaust mods are worthwile and, if so, which ones give the best bang for buck. and finally, whether a $76 ebay header is just as good as a $500 tuner header ...
