04-30-2010, 11:22 AM
#1
Replaced Clutch, no reverse gear now
Hello.
I replaced the clutch yesterday and once i took the car off the lift, there was no reverse. I didn't have time to go back in and see whats wrong yet (had to go out of town).
Figured, I may have knocked the shift linkage out of adjustment, but first 5 gears work just fine. I just cant put the shifter in reverse.
Any Ideas? Is there some sort of a reverse-lockup that I could have broken?
Any Ideas would be apreciated.
P.S. its 2002 2.7 5-speed manual
1983 928 S Euro- fun to work on
2002 Boxster- fun to work on, being able to drive it is a bonus
04-30-2010, 10:01 PM
#2
You didn't put the clutch disc on backwards did you?
Cheers!
05-01-2010, 03:12 AM
#3
Shifter linkage needs to be adjusted, the passenger side one is out of whack.
2001 Boxster S 3.6L, Zeintop
"Calling upon my years of experience, I froze at the controls." - Stirling Moss
05-01-2010, 01:05 PM
#4
No, Clutch is put in correctly, otherwise the car wouldn't have forward gears either and it does.
Thants what I thought, probably the linkage. Will see if adjustment fixes the problem and will post the results.
Thanks for the input
05-03-2010, 10:08 PM
#5
Got it sorted out. shift linkage (right-left) was out of wack, adjusted it and its all good now.
New clutch sure feels good, didn't even realize how worn the old one was until i replaced it.
Pedal is alot lighter, it engages just off the floor now.
Takes some getting used to though, killed the car twice already.
Alex
05-04-2010, 07:18 AM
#6
Alex
How hard was it? I've done two clutches before, one rear drive (easy), and one front drive (medium difficulty, Toyota Camry). Not too excited about the P car for when it's due...
Jonny Wonder
1999 Porsche Boxster 5 Spd
Stock, with GAHH A5 Glass top.
Previous Toys:
2005 RX-8, RIP
1989 GTA, 5 Speed, Procharger Supercharger and 2 Core Intercooler, 1 3/4" headers, 3" Flomaster Exhaust, cat-delete, digital ignition, bigger fuel injectors
05-04-2010, 09:39 AM
#7
Not too bad. I never replaced the clutch before, so I had nothing to compare it to.
I did have access to a lift though, which makes it a bit faster than doing it on jack stands.
My buddy, who was helping me with the process said that it was much easier than replacing clutch on his trans-am.
Once you remove the Bumper, exhaust, braces, sway bar etc, transmission becomes easily accessible.
We supported the rear side of the engine from the top (bar across).
Unbolt the cv axles from the tranny and hang them down, remove the trans mounts (from transmission and the body, not the big nut on the mount as it will ruine it).
Unbolt the slave cylinder and pull it out, pop off the linkages and a reverse switch cable and you are ready to pull the transmission.
It is held be several bolts, nut and one hex (we had to cut a Snap-on socket as it was hitting the transmission to get that sucker out).
These clutches are push type, so once transmission is unbolter - you just ply it off.
We kept the original flywheel, as it had litle wear and almost no burn marks.
Clutch, pressure plate, pilot and throw-out bearing were replaced along with all the bolts.
It took me almost an hour to install new rear main seal because I lubricated the outside edge of it (Mistake, as it only makes installation harder).
Overall its not hard, just time consuming. It took me $500 in parts and 8 hours with pizza breaks, looking for tools, screwing around etc.
If I was to do it again - would have been done in 5-6 hours.
Alex
05-05-2010, 03:59 PM
#8
Actually one of the easier cars to pull the gearbox on. If you can do it on a lift, it's not bad at all.
Boxster S
07-17-2010, 08:56 AM
#9
Shift Linkage Adjustment
"Got it sorted out. shift linkage (right-left) was out of wack, adjusted it and its all good now."
Hello al83s,
I haven't changed the clutch, but have a similar problem with the old reverse selection. I've managed to get it in once, and it's fine once it's in. The first 5 are fine so I'm hoping a little adjustment will sort it out.
Can you let me know how it's done?
Cheers,
Matt B
