Old 04-21-2010, 09:19 PM   #1
Fuel pressure gauge?
Hi guys,
I beleive a few of you have installed fuel pressure gauges. Any tips on where you installed the sender unit?
Regards,
Sam
sparker is offline   Reply With Quote
Old 04-25-2010, 06:19 PM   #2
Anyone got any tips?
Old 04-26-2010, 02:37 AM   #3
some sending units can screw on to the fuel line test port...in engine bay
extanker is offline   Reply With Quote
Old 04-26-2010, 04:37 AM   #4
Perfect, I'll take a look at this and see what the thread is.
Cheers,
Sam
Old 04-26-2010, 05:23 PM   #5
BYprodriver's Avatar
I assume the fuel rail valve is the place to attach, just be sure to install a isolator by the firewall that sends a nonflammable liquid to the gage in the passenger compartment so no fuel gets inside in case of fire.
Old 04-26-2010, 05:25 PM   #6
yeah - if there is a threaded test port on the fuel rail, I will either mount the transducer or an adaptor for the transducer directly to the fuel rail so I only have to run wires into the cabin.
Thanks,
Sam
Old 04-26-2010, 05:46 PM   #7
Thanks,
Sam
Oh I was talking about a mechanical guage not electric. Mechanical is supposed to be much more accurate & reliable. Try autometer if you don't have one yet.
Old 04-26-2010, 05:50 PM   #8
I prefer to use digital signals, they can be much more accurate if you have them setup correctly. Then you can use the signal to control a multitude of things (warning lights, nitrous safety switch, gauges, etc.)
Thanks though
Sam
