Old 04-14-2010, 10:26 AM   #1
battery change/windows
I let my battery die this winter (yes, I know, I should have kept it charged) and after installing a new battery I knew I had to cycle the windows. The passenger one was and is fine, however, the drivers side worked for a couple of times then did not want to go up. I tried turning the key in the door to make the window go up but only the passenger side worked. Any ideas would be appreciated
greybox is offline   Reply With Quote
