Old 04-07-2005, 11:56 AM   #1
Sounds like you've got a tiny one somewhere. I have one on that side, but it's nothing major and I'm not planning to fiddle with it yet. I think it's a valve cover gasket and it may just need to be tightened a bit.
Get it checked out so you know what you are dealing with. If it's under warranty, make the dealership diagnose and correct it asap.
Old 04-07-2005, 01:42 PM   #2
Dang, 2001 with only 6k miles. Maybe a seal or two dried up?
'03 3.2L GuardsRed/Blk/Blk---6Spd
Options: Litronics, 18" Carrera lights, Bose sound, Painted to match roll bars.
http://i100.photobucket.com/albums/m...Mautocross.jpg
Adam is offline   Reply With Quote
Old 04-07-2005, 02:18 PM   #3
Lux
Yup. Sounds like a valve cover leak. Oil dropping on the exhaust manifold and burning.
Lux is offline   Reply With Quote
Old 04-07-2005, 04:43 PM   #4
Brucelee's Avatar
Cam cover!
Old 04-08-2005, 05:47 AM   #5
Thanks all.
Sounds like cam cover or valve cover leak is probably it. I'm new to Boxsters. Can I get to those myself? If so, where/how? I guess worst case is have it looked at during my next oil change.
rconde is offline   Reply With Quote
Old 04-08-2005, 06:56 AM   #6
Brucelee's Avatar
I believe you need to pull the engine on this but I am not sure. I had the cam covers done under warranty on an S a ways back so I am not sure how much this costs if you are paying out of pocket.
A call to the dealer should clarify.
Old 04-08-2005, 09:04 AM   #7
I bought this used. What is the duration of the factory warranty, and if it's within the duration does it apply to a secondary owner?
