Old 04-05-2010, 09:56 PM   #1
Well if you'd like to be the guinea pig to try a bunch of generic parts to make a 485HP Boxster with front mounted intercooler and re-locate your front mounted battery, be my guest. Let me know how well it works out.
Boxster S
Old 04-06-2010, 12:22 AM   #2
Looks great
If this system is legit and doesn't blow your engine (not likely), I would buy two .
Old 04-06-2010, 05:48 AM   #3
Exactly. The phrase "you get what you pay for" applies
Boxster S
Old 04-07-2010, 06:18 AM   #4
Those manifolds look nice.
Old 04-07-2010, 06:36 AM   #5
I highly doubt you are going to get 485 hp out of a low boost application. This is very generic, as you can tell by the battery relocation kit...I'm sure it gets in the way mounted in the frunk.
Remember, if it sounds too good to be true...
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
Old 04-07-2010, 10:01 AM   #6
You will note that the 485hp top end is with 25+psi of boost. Someone needs to install one, crank it all the way open and see which blows up first, the kit or the engine.
ARModen is offline   Reply With Quote
