Old 03-18-2010, 06:17 AM   #1
Hey Jake--need an opinion
here's a link to a Boxster with an engine noise; would appreciate a comment on what it sounds like to you.
thanks, Mike
http://www.youtube.com/watch?v=MPu-5FnTEcg&feature=email
2013 Boxster S
2006 Boxster--sold
1999 Boxster--sold
MikenOH is offline   Reply With Quote
Old 03-18-2010, 03:23 PM   #2
BYprodriver's Avatar
thanks, Mike
I don't think that's a rod but I definetly wouldn't run the engine till you fix the problem.
Old 03-18-2010, 04:33 PM   #3
Topless's Avatar
Lifter noise or worn timing chain tensioner is my guess. Either way shut her down.
Old 03-19-2010, 06:38 AM   #4
Engine Surgeon
Collapsed lifter.
But you know, those never happen according to lots of "forumites", so it must be something else.
US Patent 8,992,089 &
US Patent 9,416,697
Old 03-21-2010, 02:45 PM   #5
Hi Mike, is your car still under warranty?
What's your mileage? What oil? What oil change interval?
Thanks.
Old 03-23-2010, 04:49 AM   #6
I had a similar noise. Engine chain-like noise emanated from the water pump (Jake found it). Easy enough to remove belt and check shaft play.
Good luck.
jbox53 is offline   Reply With Quote
Old 03-23-2010, 06:11 AM   #7
The warranty expired in late nov 09; 23K; M1 every 5-6K.
Thanks.
2013 Boxster S
2006 Boxster--sold
1999 Boxster--sold
Old 03-23-2010, 12:47 PM   #8
Sure sounds like a lifter.
I just heard that same sound from my car a few days ago. My car was in pieces for 3 months while I replaced wheel bearings, flywheel, clutch, and pressure plate. When I first started it, it had the same ticking sound (collapsed hydraulic lifter) -- but once the engine fully warmed at idle the lifter repressurized and the noise went away. I've been driving it for the last few days (boy I missed this car!) with no reoccurance of the sound.
As far as what should you do? Take it to the dealer and fight for warranty coverage, given your low miles and recent warranty expiration it should be an easy fight.
If you don't want to do that, you could try an oil additive that cleans hydraulic lifters and hope it solves the problem. But I would caution driving the car with a collapsed lifter -- idle speeds are bad enough, driving around putting revs and load on the engine will make things worse.
-- John
'00 Boxster S
'86 911 Carrera Coupe (Sold)
Lucky is offline   Reply With Quote
Old 03-23-2010, 01:33 PM   #9
Engine Surgeon
Something added to the oil that cleans lifters will make the problem WORSE. The reason for this is the lifters only have ONE hole that allows oil to enter into them, oil does NOT pass through them.
So adding something to the oil that cleans the lifters simply washes the other debris in the engine into the lifters and tensioners.
If the lifters had two oil passages, and oil passed through them the additives may be effective.
US Patent 9,416,697
Old 03-24-2010, 06:53 AM   #10
Jake:
When you have inspected a collapsed lifter--was it due to foreign material clogging the lifter, bad lifter design, both?
Mike
2013 Boxster S
2006 Boxster--sold
1999 Boxster--sold
Old 03-24-2010, 08:40 AM   #11
Mike, I am confussed. The Boxster in the video is black. The car in your signiture line states Guards Red.
Is this your car in the video? Thanks.
Old 03-24-2010, 02:03 PM   #12
No, that is not my car; I have an 06 that was making the same noise as the one in the video, so I posted the link to see if I could get an opinion on what the problem might be.
2013 Boxster S
2006 Boxster--sold
1999 Boxster--sold
Old 03-24-2010, 02:21 PM   #13
^OK, Mike. I understand better now.
Now, next question(s), "is" your car making this noise, or "was" it making this noise?
What does the print-out of the 6 Ignition Ranges look like on your DME? This would be very good to know.
Did you recently miss a shift? Spin the car? Bounce off the Rev Limiter?
Old 03-24-2010, 02:46 PM   #14
JTP
Jake, if the lifters have only one hole for lubrication, can new lifters be modified with two holes when replacing them? If this is possible, will this eliminate the collapsed/sticking lifter issue?
JTP is offline   Reply With Quote
Old 03-24-2010, 05:12 PM   #15
Had the car out today and the noise is greatly reduced; barely noticeable but still there. I have been trying to keep the revs down till I know what's going on here but the few times I took it up to 5K, it felt a bit rough--not as smooth as in the lower ranges.
I'll know more when the car gets looked at next week.
No missed shifts,spins or bounces off the rev limiter. it's just come out of a winter hibernation and started making this noise after being fully warmed up with a20 minute drive at highway speeds.
2013 Boxster S
2006 Boxster--sold
1999 Boxster--sold
Old 04-18-2010, 10:36 AM   #16
Update?
Mike,
Any update? What did the noise turn out to be?
-- John
'00 Boxster S
Old 04-18-2010, 05:40 PM   #17
Mechanic thought it was a collapsed lifter, which had "refloated"it self as the car was driven more. Said he had seen cars that had this same noise that took nearly a month to clear up.
2013 Boxster S
2006 Boxster--sold
1999 Boxster--sold
Old 04-24-2010, 02:03 AM   #18
ohioboxster's Avatar
Mike, we had this talk over dinner. You know the next move....do we need to go to dinner again?
2002 TT
Old 04-25-2010, 03:39 PM   #19
Matt:
You're too funny--I'm all for dinner; BTW,Marty should be back in a week or so.
I have to say, Rita was ready to write the check when she saw your car. Having said that, right now we'd have to sell the Boxster to do it and I'm not sure she's ready to part with it--yet. Still working on it.
I'll get a date from Marty and see if set up a time to get together.
BTW, we're doing Mid-OH with NNJPCA first weekend in June; great group to run with with you can get the time off...
2013 Boxster S
2006 Boxster--sold
1999 Boxster--sold
