Old 03-14-2010, 04:13 AM   #1
Reverse Camera mounting/wire routing?
Hi Guys,
about to install a reversing camera in my 986 (see pic below of the camera I'm using) and just curious on how others have mounted and routed the wiring? Im planning on making some small brackets to actually mount the camera to the rear license plate which will hold it just above the rear plate.
Has anyone else mounted a rear camera on a boxster before? Any tips/tricks you learnt from your experience? I'm planning on just powering the camera off the reverse light power, but im not sure where I can route the wiring for power/video for the camera. At this stage Im thinking through the license plate lights? Could just put a tiny slot there to get the wires through?
Cheers,
Sam
sparker is offline   Reply With Quote
