Old 03-01-2010, 04:06 PM   #1
2003 S widest rear tire fitment
What is the widest tire that I can run in the back? (including using spacers if needed)
Currently have the stock 18/35/265
the car is now having problems hooking up when launching from a stop. and i need wider rear tire.
I did a search and I couldnt find a simple answer. just what is the widest tire without rubbing issues??
Thanks.
2003 Boxster S
2K3_Boxster_S is offline   Reply With Quote
Old 03-01-2010, 04:53 PM   #2
I think you need stickier tires instead.
Old 03-01-2010, 07:25 PM   #3
+1 ................
Old 03-01-2010, 07:34 PM   #4
They are high perfomance tires
Bridgestone Potenza RE 01's
although they are a summer tire and it has been in the 40's.
still would like to know.
2003 Boxster S
Old 03-01-2010, 09:32 PM   #5
TriGem2k's Avatar
Send a message via AIM to TriGem2k
Stock 18inch wheels are 9" wide. I wouldn't go wider than a 275mm and that is pushing it. The 9" wheel is designed for a 265mm tire
-GT3 Front Bumper w/ Lip
-Side Skirts
-Gemballa Exhuast and Cats
-O.Z. Racing 18" Wheels
--18X8.5Front 18X10 Rears
-5mm Rear Spacers
-Porsche Door Sills
-H&R Springs
-Powerflow Intake
-B&M Short Shifter
-Focal Polyglass 165VR3
-Alpine PDX 5 Amp
-Audio Controld DQXS (DSP)
TriGem2k is offline   Reply With Quote
Old 03-02-2010, 04:14 AM   #6
mts
You wheels are designed for a 265mm. However, you can do up to a 285mm in the newer high performance tires. A good friend is head guy for one of the major brands and indicated that would be within safety tolerance of the newer tires. That being said, I run 265's.
2004 550 SE #1081 of 1953 (sold)
1997 911 Targa (sold)
mts is offline   Reply With Quote
Old 03-02-2010, 08:43 AM   #7
But if it was in the 30s overnight
and just now into the 40Fs the pavement may still be cold enough that the tire doesn't get warm enough for the "rubber" in the compound to deform and fit into the micro-irregularities in the pavement which is what gives you traction in a summer tire.
Wait till a day when it has been only in the 50Fs at night before making a judgment.
And be extremely careful any time the pavement has been colder than about 45 with summer tires...cost me a '99 when I applied the brakes and just slid in the morning when the temperature was probably 40 degrees but it had been colder the night before.
Old 03-02-2010, 09:03 AM   #8
That's your issue. If it's below 45 or 50 outside, my 2.7 will break the rear 255 SP Sport Maxxs free if I go WFO while rolling in first. That shouldn't happen with 192 ft-lbs, and it has everything to do with the temperature.
If you want better traction in cold weather, get a UHP all season made of rubber designed to function in lower temperatures. 265s are plenty wide for an S, and I doubt that the same tires in a 285 width will make much of a difference with your wheelspin with those temps.
http://ericfilcoff.com/pictures/986forum.jpg
2001 Boxster | 2007 Outback Sport
Need a freelance graphic designer?
Samson is offline   Reply With Quote
Old 03-02-2010, 09:19 AM   #9
Tyres
I run 285 30 18s on my 01 with sports suspension. No rubbing and they look fab
gayboy is offline   Reply With Quote
Old 03-02-2010, 11:14 AM   #10
Topless's Avatar
If you need wide and super sticky these will fit your wheel wells. Not much use at 40deg F though:
http://www.tirerack.com/tires/tires.jsp?tireMake=Kumho&tireModel=ECSTA+V710&sidewall=Blackwall&partnum=83WR8EV710
Old 03-02-2010, 08:20 PM   #11
Thanks All,
I realized quickly. the car is scary in temps below 40.
2003 Boxster S
Old 03-04-2010, 05:05 PM   #12
Cold Weather
Definitely the cold temps are the issue. I have destroyed my Michelin PS2 this winter in 30-40 degree temps. The tractions control light stayed on so much I thought it was going to burn out.
1997 Boxster 986
TechArt Championship Formula OZ Wheels,
TechArt Springs
TechArt Strut Brace Front and Rear
Technobrace (Thanks Pedro)
Michelin PS2
G2 Red Caliper Paint
DamageINC123 is offline   Reply With Quote
Old 03-04-2010, 07:25 PM   #13
I want to get rid of my stock rims (18" carrera lights) I see alot of people running OZ rims. How is the weight compared to what I have?? obviously i don't want a heavier wheel.
2003 Boxster S
Old 03-05-2010, 10:28 AM   #14
Weight??
I have never weighed my rims so I would not be able to tell you. I have heard that OZ boast about having some of the lightest wheels on the market. Mine were already on the car when purchased.
This I have read, "If considering rotational enertia test show that 1lb of tire weight is equal to 8lbs add to vehicle weight while 1lb of wheel weight is equal to 6lbs added to the vehicle weight"
Times this by 4 and it adds up quick.
You can google Dave Coleman and rotational inertia.
1997 Boxster 986
TechArt Springs
Michelin PS2
