Old 03-02-2010, 10:03 AM   #8
Samson
Originally Posted by 2K3_Boxster_S
They are high perfomance tires
Bridgestone Potenza RE 01's
although they are a summer tire and it has been in the 40's.
That's your issue. If it's below 45 or 50 outside, my 2.7 will break the rear 255 SP Sport Maxxs free if I go WFO while rolling in first. That shouldn't happen with 192 ft-lbs, and it has everything to do with the temperature.
If you want better traction in cold weather, get a UHP all season made of rubber designed to function in lower temperatures. 265s are plenty wide for an S, and I doubt that the same tires in a 285 width will make much of a difference with your wheelspin with those temps.
http://ericfilcoff.com/pictures/986forum.jpg
2001 Boxster | 2007 Outback Sport
Need a freelance graphic designer?
Samson is offline   Reply With Quote
