Old 01-20-2010, 02:12 AM   #1
Oil Leak Question, not RMS or MS
Hey guys, recently my box has been dropping oil like there is no tomorrow. Its let out at least 8 quarts over the last 3 weeks or so.
I had a buddy of mine whos finishing up his degree at WyoTech in PA take a look (he is currently in contract negotiations with Porsche to work for them) at it and he said its coming from the top of the engine on the right side. The RMS and MS are both intact, the trail and spray of the oil indicate it came from the topside.
Now, I had about a 8 or 9 beers when he told me this (small house party and he wanted to take a peak at it while some of us were smoking) and he said it was either the _____ gasket or the ______ valve right under the passenger/right side intake.
Would anyone happen to know which gasket and valve he is referring to, how much they cost (parts), and if I would need any specialized tools to do the job? I know he can do it for me, I just would like to know if I'd be able to do it myself.
Thanks,
Adam
PlayersExpress is offline   Reply With Quote
Old 01-20-2010, 05:19 AM   #2
dalealan2001
Guest
Posts: n/a
Maybe if you smoked and drank more you would remember!. lol
Old 01-20-2010, 02:55 PM   #3
Thanks,
Adam
There's a good chance he was talking about a crankcase vent tube/valve (but I believe it's on the driver side) and/or a head gasket. The thing is I don't think the M96 uses traditional head gaskets. I believe it uses a liquid style sealant like permatex. That's a huge oil leak. It should be fairly easy to see where it's originating from. Put the top in the service postion and if you still can't find it, make sure the engine has plenty of oil and start it. Once the oil is under pressure it should become apparent.
'03 3.2L GuardsRed/Blk/Blk---6Spd
Options: Litronics, 18" Carrera lights, Bose sound, Painted to match roll bars.
http://i100.photobucket.com/albums/m...Mautocross.jpg
Adam is offline   Reply With Quote
Old 01-20-2010, 05:00 PM   #4
dallison's Avatar
clean the motor and see where it leaks.
dallison is offline   Reply With Quote
