12-16-2009, 07:55 AM
resetting radio
does anyone have the radio lock code and info. required to reset the radio when the battery is reconnected?
im going to install rear speakers.
thank you in advance.
12-16-2009, 08:21 AM
Every radio that uses a code (MOST bus radios do not have codes) has a unique code that only works with that radio…………
12-20-2009, 11:50 PM
If you PM me with the serial #, I have the software to decipher the code.
02-03-2010, 04:01 AM
Do you need the serial # of the radio to get me the code?
02-03-2010, 12:19 PM
I also thought that the user could change codes if they wanted. I have a buddy of mine that recently purchased a 99' and has tried all sorts of translated codes that should have worked, but do not. Is there a code that is always, always embeded in the unit no matter what?
Interesting.
02-03-2010, 01:56 PM
Yes, you need the serial #.
To get the serial number, power up the unit and hold down the "TP" button for 10 seconds. The unit will beep once, use the knob to scroll over a few times and you'll see a seven digit number, preceded by a letter - that's the ser.#
Cheers!
02-03-2010, 02:19 PM
I dont have the 2 knob stereo. Is there something else I need to do to get that # for you? My stereo has the up/down buttons on both ends.
2006 Hummer H3 - RED 76k mi - LIFTED - 3rd row custom seating on 35's and a manual tranny.
1997 Boxster Guards - RED 86k mi - 19" Lobster Claw Wheels on Conti's , Porsche side decal for extra "speed", manual tranny -signed by Hurley Haywood
Phoenix, Arizona
02-03-2010, 02:23 PM
You don't have a button marked 'TP'?
Well, if you use a couple radio keys (absent the keys, a couple paperclips may work), you can slide the unit partially out of the console and the ser# is on a sticker on the bottom.
Cheers!
02-03-2010, 02:26 PM
Interesting.
No... the code is hard wired to the chassis. It cannot be changed.
Cheers!
02-03-2010, 04:45 PM
FYI. sounds like you have the CDR 210.
'98 Artic Silver w/ Tip
02-19-2010, 04:57 AM
OK, I am ready to do this but I need HELP. I have looked at the previous link but this does not seem to work. I have the CDR-210 stereo. Serial # is on the back of the faceplate (I think) and so I need to know how to get the code from here. I tried what was on the previous link and could not seem to figure it out. I didnt get home from the airport until 1am and tried it then. Maybe too long of a day or something, but I have the new bracket for behind the airbag so I need to get the code. Thanks in advance to all for your help.
Phoenix, Arizona
02-19-2010, 08:34 PM
Anybody that can help with a code?? I have tried a few that I have found online and have had no luck. Please let me know what information I need to get to somebody and I will do that asap.
Phoenix, Arizona
02-20-2010, 06:14 AM
SEND ME THE SERIAL # AND I CAN GIVE YOU THE CODE!
SERIAL # IS ON A STICKER ON THE BOOTOM OR BACK OF THE UNIT!
USE RADIO KEYS OR PAPERCLIPS TO PULL THE UNIT FROM THE CENTER CONSOLE AND PM ME.
Cheers!
02-20-2010, 06:36 AM
Pm Sent Check Inbox
Phoenix, Arizona
02-20-2010, 08:17 AM
Code sent
Cheers!
02-20-2010, 08:23 AM
Originally Posted by Lil bastard
Code sent
Cheers!
Response sent. Thanks
Phoenix, Arizona
02-22-2010, 06:20 PM
Yellow stone diesel parts plant is one of the leading manufacturers
of engine parts, in particular diesel fuel injection system
accessories for replacement, such as Fuel injection Nozzle, Plunger and
Delivery valve, ETC In south of china .
for more detail please visit our website : www.yellowstonediesel.com
www.dieselinjection.cn
Yellow stone diesel parts plant was founded in 1997.Over the years,
Yellow stone has grown and gained a reputation for producing
high quality products and delivering them on time.
04-06-2010, 08:04 PM
Recovering Radio Code
The following online decoder allowed me to recover my radio code without pulling the radio. Very nice!
http://www.a2dvoices.com/realitycheck/porsche/
05-05-2010, 01:54 PM
I tried entering a couple of codes, now my head unit won't even turn on. Is there a special sequence of buttons I need to push?
Thanks,
tw
