Old 12-02-2009, 04:23 PM   #21
Also you could try 0 toe in back if you want the back end to rotate more easily. Toe out on the back will make it an oversteer like crazy and is not recommended. Rear toe in will add rear stability.
'03 3.2L GuardsRed/Blk/Blk---6Spd
Options: Litronics, 18" Carrera lights, Bose sound, Painted to match roll bars.
http://i100.photobucket.com/albums/m...Mautocross.jpg
Adam is offline   Reply With Quote
Old 12-02-2009, 06:14 PM   #22
jacabean's Avatar
This is what I am going to do . I will start by adjusting the coilovers until I get some reasonable clearance . find a good alignment shop . see how that works out , hopefully before we get snow. then maybe some stickier rubber. I am getting the feeling that the pirellis don't have enough grip. Thanks everyone the info is greatly appreciated .
Old 12-03-2009, 04:01 AM   #23
What tire sizes are you going with?
