Old 06-29-2010, 01:02 PM   #36
Originally Posted by jhandy
I have the raby underdrive. It is the smallest pulley made that still allows you to drive the car daily.
i am assuming you ment to say - put an underdrive and a small pulley for the power steering?
I think that this would be too much. one or the other.
if i am at idle, my alt puts out 12.9-13.0 volts. my power steering works great, but i can tell any less pressure would be too little.
Also if i turn all electrical things on the car, the lights, ac radio, radar dectector, sat reciever, heated seats....eveything... my output at idle reads 11.9-12 volts.
so you can see any slower would not let the car recharge the battery.
Also the advantage of the underdrive over the steering pulley is that it slows the steering pump, and it lowers rotational mass of the crank at the same time. increasing torque and a little HP. just a steering pulley should not do that.
i recommend the raby pulley 110%, for around 300$ and a little work, it is the best bang for the buck hands down.
DONT FORGET THE NEW BOLT AND WASHER!!! dont cut corners or you risk sittng on the side of the road.
Thanks for the feedback JHandy...Seems like a great mod still, just wondering whether it's better for a daily driven car to go with this smaller 4" pulley, or to go with the slightly larger, but still smaller than stock underdrive pullies from Mantis/BBI/RSS, etc. Since those are a size in between comparing the stock pulley and the small 4" pulley, I'd imagine some hp free'd up, but not as much as the 4" pulley, yet less of the accessory/charging issues of the smaller pulley.
And I did indeed mean, smaller crank pulley, and larger power steering pulley for the underdriving system..
Seeing as you experienced some, albeit slight side effects of the underdriven system when you have all of your accessories on, if you were to have an ideal situation or do it all over again, would you consider the other 'slightly less' underdrive pulley offerings, or would you still stick with the 4" pulley? (when all accessories are on, ie, lights, AC, radio, etc, is it enough of a difference to be annoying at all?)
Thanks in advance for the feedback again...
http://farm4.static.flickr.com/3420/...90927559_o.jpg
Some stuff for sale: M030 S 24mm front sway bar, M030 base 19.6mm rear sway bar, 996 GT3 OEM Porsche Motorsport front strut mounts monoball "camber plates"
WTB: looking for some 5-7mm spacers with extended bolts
chaudanova is offline   Reply With Quote
