Old 10-02-2009, 03:28 PM   #1
Horn honks when I hit the brakes
On a fast stop my horn honks and hitting bumps while going down hill. I think it may be the horn button. anyone know if it is difficult to replace?
1999 Boxster
ironcfo is offline   Reply With Quote
Old 10-02-2009, 03:49 PM   #2
Yes a common problem AND a common topic here on the forums... to quote myself:
Originally Posted by kabel
The bushings in the horn frame have weakened and need repairing. See this very recent thread from just a couple weeks ago:
Stuck Horn
If you want to read more about it there are a few threads about that here and a really good one over on Rentech.com Horn Problem, Horn problem
other threads here on 986forum:
Please HELP! Horn going off on its own
My Car Honks When I Brake!!!
Horn doesnt stop Honkin...
kabel
Orlando - 99 BMW M Coupe (autocross toy), '11 Mazdaspeed 3 (dog hauler), '99 10AE Miata (the new daily driver)
kabel is offline   Reply With Quote
Old 10-04-2009, 09:05 AM   #3
Thanks for the help, very good information. Looks like something I can do. Any precautions needed with the air bag during change out of the bracket?
Gary
Old 10-04-2009, 12:35 PM   #4
Battery disconnected is the big precaution
air bags can kill at short range.
Old 10-04-2009, 03:57 PM   #5
air Bag
other than battery disconnect any special handling of the air bag while repair is being made to the horn bracket?
Gary
Old 10-04-2009, 04:12 PM   #6
First... disconnect the battery!!!
I used a small screwdriver to pop the plug off the backside of the air bar (once it was loose from the steering wheel). the plug was pressed in pretty hard, but with the screw driver popped it right out. No tab or nothing to have press when popping the plug out.
My Porsche mechanic drives a Saturn.
'98 Artic Silver w/ Tip
vath2001 is offline   Reply With Quote
Old 10-05-2009, 05:39 AM   #7
When you say pop the plug
I assume you are refering to the electrical connector? Nothing else holds the bad in place? Sorry for belaboring this just want to get it right....
Gary
Old 10-05-2009, 05:52 AM   #8
Gary,
Yes. Simply disconnect the battery (all you need to do is remove the negative side). You will need a Torx driver to remove the two bolts on the back of the steering wheel (T-25 I think). The thread lock on those bolts is pretty strong. The air bag will come loose, there is a small plug connector on the back of the airbag, disconnect that connection and the airbag should be free.
kabel
Old 10-05-2009, 07:51 AM   #9
thanks for all the great input. Looks like a simple fix. I have the part on order.
Gary
Next item on my list is the head light switch. Sometimes have to turn it on and off and on to get my lights to go on!
Really not too bad for a ten year old car.
Old 10-17-2009, 12:09 PM   #10
Okay, Done!
Very simple job. Took about an hour to replace the part. Hardest part was getting out the Torx screws holding the air bag in place; only had a driver had to use a pipe wrench on it to break them loose. Air bag comes out easily and bracket replacement a snap. Tested no more unwanted honking.
Old 10-17-2009, 06:28 PM   #11
When I first read your thread title, I seam to remember wiring a friend's brake light switch to his horn as a joke! I'm glad to hear you've fixed the issue.
941MXVET is offline   Reply With Quote
