Old 10-06-2009, 05:24 PM   #1
Please Help - Car Failed Test
Hi guys I am in need of help. My 97 box failed its emissions test and I have 2 days to fix it and pass the test before the box goes into winter storage again.
My problem is that in the Hydrocarbons test the maximum allowable is .5000 and my car read .7721
The carbon monoxide and NOx test passed just fine.
I started getting a CEL when I installed the cheap aftermarket headers. The car was also in storage for about 8 months before I started it, did an oil change, ran it for about 1 hour before the test (with the stale gas). My questions is should I swap back to the stock headers and hope all goes away? My headers had 02 bungs for later model cars but my model year only has 2 sets of sensors. The 02 bungs that aren't used on the new header are plugged up with old 02 sensors to fill up the holes.
I have a OBD2 reader attached and it reads:
P1125
Oxygen sensor adaptation, upper load range, Bank 1, above limit.
Anyone knows what this means?
Perhaps I just need new 02 sensors? Or maybe the new headers aren't working with the onboard computer? Perhaps the 02 bungs on the new header is leaking air? Perhaps the new header wasn't installed well and is leaking air?
I am no emissions expert and not even sure why the header would affect the results. Perhaps it was due to the car being in long term storage? But the CEL was on.
Thanks in advance
97 Arctic Silver/Boxster Red
Carbon Everything
De-ambered
De-snorkled
Litronics
Eibach Pro Kit
Dansk Sport exhaust
Cheap Chinese headers
Silver console and bumperettes
AVIC D3
15mm H&R spacers in the rear
SSR GT3 19's
GT3 Carbon Replicas
Alcantera door panels
JL Aduio 5 channel powering Polks and Clif Designs
To do/complete:
Elemental Designs 10" subs in fiberglass enclosures behind seats
Carbon 3 spoke install with custom stereo control buttons (tiptronic wheel)
angman is offline   Reply With Quote
Old 10-06-2009, 05:33 PM   #2
I assume the cheap headers have no cats. Catalytic converters are technically called 3-way catalytic converters - they reduce the following three things from your emissions:
Carbon Monoxide
Hydrocarbons
Nitrogen Oxides
I'd reinstall the OEM headers, drive for a while to ensure all is emissions-ready, and try again.
In CA (I believe) a check-engine light is an automatic fail - I don't think they'll even sniff the exhaust. If you disconnect the - terminal of your battery to clear the check engine light, you may have to do a fair amount of driving to get the car emissions-ready. Google 'boxster emissions drive cycle' or similar search terms to see if you can find some tips on how to get emissions-ready with the least amount of driving.
Many OBD scanners have an emissions-ready check to see if the computer has enough data logged to be ready for smog testing. If yours has this feature, it can help take some of the guesswork (and $$$) out of wondering if you're ready to try again.
sd_boxster is offline   Reply With Quote
Old 10-06-2009, 06:15 PM   #3
google is your friend!! I just put in "how to pass an emissions test" and got back thousands of results. You will have to go trought them to see what is BS and what is legit.
http://www.squidoo.com/howtopassemissionstest
Also, filling up your fuel tank with gasoline that contains 10% ethanol alcohol (many premium grade fuels use alcohol as an octane booster) may help lower your emissions even more. Many areas now have "reformulated" gasoline that contains alcohol or MBTE that adds oxygen to the fuel to reduce carbon monoxide and hydrocarbon emissions.
The Fuel Atomizer 2000 has helped people pass the emission test all along the west coast. I work for Wyoming Kustom GEAR LLC. so I might come across being partial but, people have reported tremendous results. A car up in Canada was reading 1620ppm of hydro-carbons and it brought it down to zero. It cost about $150 but it also cleans the inside of the engine and increases mileage. Let me know if you want more info.
http://www.heartland.org/publications/environment%20climate/article/13139/How_to_Pass_Your_Emissions_Test.html
I'll take my Guns, Religion, and Money; You can keep the "CHANGE" B.O.!!
SO, GROW A PAIR NANCY AND DRIVE IT LIKE YOU STOLE IT!!
http://i826.photobucket.com/albums/z...Main/MyBox.jpg
mptoledo is offline   Reply With Quote
Old 10-06-2009, 08:03 PM   #4
Popular Mechanics reviewed the Fuel Atomizer 2000 five years ago when the mfr. was claiming a 300% increase in fuel economy...
Any objective reviews on this gadget you have found (Not trying to be a jerk - I'm just naturally suspicious miracle cures... most of 'em are designed to surgically remove extra cash from the pockets of rubes. )
Old 10-06-2009, 08:52 PM   #5
Here's what I would do if it were my car.
1) Replace the O2 sensor throwing the code. I think that would be easier than putting the old exhaust on.
2) If that doesn't fix it (or if you don't have time to do that), I would try some RXP. RXP comes in a small orange bottle and you add it to a tank of gas when you fill up. Drive with that for about half a tank and take your test.
I have used RXP twice, and it worked both times. Granted, this was with a 1994 Ford Probe GT, but here was my scenario. I went to get a state inspection and failed emissions. Put the RXP in and passed. Exact same scenario the following annual inspection.
It's about $8 a bottle, so perhaps worth a shot. Your local auto parts store should have it.
1997 Honda Accord | V6
2004 BMW 330i | ZHP | SOLD
http://kryzak.tumblr.com
Jeph is offline   Reply With Quote
Old 10-06-2009, 09:30 PM   #6
BYprodriver's Avatar
By "Dansk Sport Exhaust" I think that means 100 cell converters & those will allow an increase in emissions. Have you passed smog test with these before?
Fresh Gas will help ( Chevron premium ) & new spark plugs help too.
Hydrocarbons are basicaly unburnt fuel so you need to increase your combustion effecentcy
