Old 09-28-2009, 04:41 PM   #1
BYprodriver's Avatar
souds like the inner brake dust shield got bent & made contact. to diagnose jack up that wheel off the ground & spin the wheel
Old 09-28-2009, 05:55 PM   #2
Bob Hindson Racing
Guest
Posts: n/a
Should only take ya a minute to pull the wheel and have a look-see in there. It's likely either foreign debris between the rotor and shield, or whatever debris impacted the shield bent it such that it's contacting the rotor. If you find something worse, then it may be time for you to call your shop back.
Old 09-28-2009, 10:46 PM   #3
manolo's Avatar
I've had the same thing happen a couple of times, rotor guard was contacting rotor slightly and made that noise. Once because I tweaked it slightly during a wheel mounting, and the other when a rock got in there during a drive.
manolo is offline   Reply With Quote
