Old 09-24-2009, 06:11 PM   #1
Johnny Danger's Avatar
Heat Shielding
I've read several articles regarding the pros and cons of "wrapping" exhaust headers. Perhaps, someone can give me some advice. I recently installed a set of custom fabricated headers and cats on my 986 Boxster S. Unfortunately, the position of one of the headers now comes in close contact with a rubber engine hose of some sort. Is there a material that one could use that would shield the hose from the exhaust header. I would prefer to not wrap the header. Therefore, could I instead wrap the hose with the appropriate material ?
Old 09-24-2009, 07:20 PM   #2
That should be the power steering line. If it melts through, you will see a huge amount of smoke and some have reported fires occuring.
zip tie it out of the way, and wrap the headers. If the headers are custom made, maybe the guy can make a custom heat shield. I would buy a fire extinguisher and keep in the car.
2002 S
jhandy is offline   Reply With Quote
Old 09-24-2009, 07:25 PM   #3
Could I instead wrap the hose with the same material ?
Johnny
p.s. Its the large hose on the passengers' side.
Old 09-24-2009, 08:23 PM   #4
Jaxonalden's Avatar
Check this site, ( http://www.thermotec.com/ ) I use it on a number of applications. Wrapping your headers will cut down on under hood temps on conventional cars. Ours on the other hand will not because our exhaust exits down into the airflow under the car. Wrapping will keep the exhaust header hot, which will keep the exhaust hot, which will keep the exhaust velocity high and will increase cylinder scavenging.
Old 09-24-2009, 11:46 PM   #5
Lil bastard's Avatar
Personally, I've always been leery about wrapping headers on a street car. Most people wrap their headers in an attempt to manage a heat problem. The arguement for better scavenge effect is all but moot until the tach is pointing at 1-o'clock or better.
In reality, all they're doing is forcing the issue downstream. I've seen many cats fail prematurely on cars using header wrap. Something to consider at least.
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
Old 09-25-2009, 07:34 AM   #6
Does anyone agree that I should wrap the power steering hose with the appropriate material in order to shield it from the header ?
Old 09-25-2009, 07:48 AM   #7
Unless you want problems, it would be a good idea, but rather than wrap it, look into heat resistant sleeve materials. Companies like Thermo Tec make heat resistant sleeve materials that are aluminized on the outside to reflect heat away. Simply cut to length, disconnect the line and slide it over, reconnect the line; you’re done. No zip ties to crap out, just thermal protection.
Most speed shops carry this stuff, it is very useful for protecting all sorts of wires and hoses…………..
Old 09-28-2009, 04:51 PM   #8
BYprodriver's Avatar
+1 on this solution those headers are way to pretty to hide
Old 09-28-2009, 05:52 PM   #9
Bob Hindson Racing
Guest
Posts: n/a
Whether you go the route of tying the line out of the way and/or shielding it, you must keep it away from the headers.
