Old 09-21-2009, 11:23 PM   #1
Thinking about this more - for what you paid, you can afford to buy another crate motor and leave it in the corner of the garage... just in case.
1999 Carrera 4 • Aero kit • 4" UD Pulley
My Corvette doesn't leak oil... it sweats horsepower.
sd_boxster is offline   Reply With Quote
Old 09-28-2009, 06:34 PM   #2
Bob Hindson Racing
Guest
Posts: n/a
Only way to investigate the RMS is to pull the gearbox. If the car has made it to 50K, the chances are extremely low that the engine will suffer a drooped bearing carrier (which is what led to engines being replaced). An RMS leak is an oil leak, just happens to be a relatively expensive one to fix.
