Old 09-09-2009, 07:28 AM   #1
Send a message via AIM to blinkwatt
Rear Speaker Compartment...
Does anyone know if the OEM rear speaker kit matched with Hi-Fi,DSP is powered by the amp or head unit?
-99' Zenith Blue 5-spd...didn't agree with a center divider on the freeway
-01' S Orient Red Metallic 6-spd...money pit...sold to buy a house
blinkwatt is offline   Reply With Quote
Old 09-09-2009, 07:59 AM   #2
if it's truly OEM (factory installed and on the option label) it'll be powered by the AMP in front trunk. If it's just OEM then it could be either.
Quick ways to check:
- make sure AMP is 6x40W (unbolt from firewall or use a mirror to read label facing firewall). If 4x40W then no. If 6x40 then make sure pins 5, 6, 15, & 16 in the larger plug of the AMP are filled.
- pull the h/u and make sure there is not a brown plug into socket B (it would be brown IIRC)
Old 09-09-2009, 08:07 AM   #3
Cool thanks! Just trying to make sure the install of my new head unit will go smoothly. Should look like this if I go through with it.
