Old 07-15-2009, 05:53 PM   #1
sway bar rubbing control arms after lowering
I Put some eibach lowering pro kit springs on last summer on my 98 boxster I just noticed after driving it this way for about a year now the front sway bar is rubbing on the control arms and actually wore in to them quite a bit there is now a half moon shaped dip in each one from the metal sway bar rubbing on them because of the springs brought the sway bar so close to the control arms ,my local mechanic thought we could put some spacers on the sway bar mounts to lower it a bit anybody else had this problem if so what did you do ????
rd400rz is offline   Reply With Quote
Old 07-16-2009, 08:53 PM   #2
Will getting aftermarket (shorter) drop links bring the bar up and away from the control arm?
kj
Boxster44 is offline   Reply With Quote
Old 07-16-2009, 10:40 PM   #3
Not sure Looks like we might have to make the links longer to help the bar clear,I see now eibach has a aftermarket sway bar ,they did not have this when I bought my springs ,mabe they know there is a problem with there springs lowering the car to much ,anybody else have any ideas?
Old 07-21-2009, 05:51 PM   #4
photos added lowering problem
here are some new photos
