Old 06-23-2009, 10:28 AM   #21
Thats what I'm talkling about. Something cheap, lightweight and functional. That would be perfect.
Originally Posted by Brad Roberts
Grant,
I have a Flowmaster setup we have used for years.. makes the car sound like it is doing 9k rpm at 4krpm. Dual in dual out.. and I cap the out and access the center chamber for a center exit exhaust. Light, simple, cheap, effective. I believe I end up with $350 in them.. and they last..
Here it is on a 914.. imagine all this hidden well by the stock Boxster rear bumper. For some reason I have not shot pictures of it on a Boxster.. but Chris Murray runs the same thing on his "Cop car" Boxster race car.
B
grantsfo is offline   Reply With Quote
Old 06-23-2009, 11:23 AM   #22
Brad Roberts's Avatar
300hp 3.6L 993 engine in a 2300lb narrow body 914 It forces you to learn how to drive
Thankfully.. it is all under the Boxster when used. We don't have a lot of room under the rear of the 914!!
B
Old 06-23-2009, 03:49 PM   #23
How did you you shoehorn that beast in there? I want to put a 2.5L in a 67-69 VW square/notchback...that would be a runner.
Do you have any videos of your 914?
yellowboxster01 is offline   Reply With Quote
Old 06-23-2009, 04:59 PM   #24
Search Youtube for 914Club. I show a dyno pull of the orange car
It is a direct bolt up to the stock 914 trans Everything up too a 3.2l air cooled Carrera engine is a direct bolt in to a 914 chassis.. I can use ALL factory engine tin, oil lines.. blah blah from a 1970 9146.
B
Old 06-23-2009, 09:57 PM   #25
Originally Posted by 2K3_Boxster_S
just curious what is your whole setup from headers back? still running stock front CATS??? interested in the dyno results. related to my NHP thread.
Oops, made a mistake, the tubing is 1 7/8". It's still stock headers and Cats. Anyways, here is a video on the dyno but I couldn't get any numbers because the dyno needs to read RPMs off the crank and that just wasn't possible without removing a bunch of covers. http://www.youtube.com/watch?v=aVMnjSyeyzQ
And some pics:
from behind
Version 2.0 with smaller resonators
Version 3.0 with larger resonators
loosecannon is offline   Reply With Quote
Old 06-29-2009, 06:01 PM   #26
LMAO that's going be in my signature for another forum.
actually, you will have to go to your local organic metal fabricator and buy conflict free fair trade metal to be made into "green" exhaust pipes. look for the certified sticker indicating that no person under 18 made it and the company was paid a fair hourly rate....LOL
I miss Reagan
1999 Boxster
Guards Red / black interior / black top
30K miles
myfirstporsche is offline   Reply With Quote
Old 08-04-2009, 07:52 AM   #27
What exhaust tips did you use?
zartman456 is offline   Reply With Quote
Old 08-04-2009, 09:23 AM   #28
Any update on the NHP exhaust yet?
2K3_boxster_S: Did you put your boxster on the dyno with the NHP exhaust yet? Interested to see the results. How does it sound? I know that $895 is a lot more than what the target is here....but it looks to be made very nicely.
Loosecanon - I love the simplicity of your design #3. What kind of dollars if you build another one? I want to shed the pounds and would love to make it a bit louder too. HP increase....that is the icing on the cake!
rob76turbo
Current Porsches: 2002 Boxster S (Speed yellow)
Past Porsches: 1972 914, 1987 944S, 1976 930, 1986 951, 1999 986, 1992 968, 2001 986 S, 2006 Cayman S, 1986 951 track car, 2001 986 S, 2005 Cayenne
rob76turbo is offline   Reply With Quote
Old 08-04-2009, 03:36 PM   #29
For me to build another one or for you to build another one? Summit racing sells the pipe for about $18.00, the stainless tips are around $30.00 and the larger pipe for the resonators is about $10.00. Any local guy with a welder and drill press can make it for you. The inside pipe is 1 7/8" and the outside pipe should be 3" or greater.
Old 08-04-2009, 07:40 PM   #30
[QUOTE=loosecannon]For me to build another one or for you to build another one? Summit racing sells the pipe for about $18.00, the stainless tips are around $30.00 and the larger pipe for the resonators is about $10.00. Any local guy with a welder and drill press can make it for you. The
Thanks! I think I can find someone local that can weld this.
Question; how did you fit the new exhaust up to the cat-back tubes? Weld again?
rob76turbo
Old 08-04-2009, 08:37 PM   #31
[QUOTE=rob76turbo]2K3_boxster_S: Did you put your boxster on the dyno with the NHP exhaust yet? Interested to see the results. How does it sound? I know that $895 is a lot more than what the target is here....but it looks to be made very nicely.
QUOTE]
still Fully stock. i keep getting sent out of town for my work. I also still haven't got an accurate (baseline) dyno of the full stock setup yet. It will be back on the dyno for the baseline middle Aug. then my setup will be full headers, bypass mids and the NHP exhaust. let you know when i get there
2003 Boxster S
2K3_Boxster_S is offline   Reply With Quote
Old 08-05-2009, 09:33 AM   #32
[QUOTE=rob76turbo]
After the cats, the factory has a small u-shaped tube in each side and the new exhaust just slides into them and clamps on. It will make more sense when you take the old muffler off. It's quite easy to fit a new one.
Old 08-05-2009, 06:06 PM   #33
Originally Posted by Brucelee
Oh, wait a minute, wrong post. Sorry.
Actually, wrong forum! Ha!
Old 08-07-2009, 06:26 AM   #34
Did you also get the tips from summit?
