Old 06-15-2009, 05:48 AM   #1
Replace Engine blower motor
Has anyone replaced their engine compartment blower motor? Mine is making a horribly embarrassing noise when it comes on. Sounds like something is hitting the fan blades or the motor bearing is going. I was simply going to order and install a new fan until I saw the price of a new blower motor assembly could cost $300+.
kabel
Orlando - 99 BMW M Coupe (autocross toy), '11 Mazdaspeed 3 (dog hauler), '99 10AE Miata (the new daily driver)
kabel is offline   Reply With Quote
Old 06-15-2009, 08:35 AM   #2
blower motor
mine was making a loud noise, as the rubbery backing of the insulation had curled down into the fan blades. do an inspection, spin the fan by hand, check for clearance.
chris dumont is offline   Reply With Quote
Old 06-20-2009, 12:17 PM   #3
Turns out a wire harness made its way into the fan blades. I was likely only a day or two away from the blades rubbing through the wire casing completely and shorting. Taped up everything good and used a cable tie to keep it out of the way.
kabel
